Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 05-21-2020, 06:21 AM
Smokin 6.0 Smokin 6.0 is offline
Lieutenant
Member's Gallery
Default ICP issue ?
Having issues with my 05 randomly dieing. Most of the time itís right after I have let out of the throttle at low speeds or when itís sitting idle. It will start to act like itís gunna die and then recover and run fine and then sometimes it dies.. every time it restarts just fine. I have unplugged the ICP and driven it that way for awhile and it hasnít ever died. One time it started hard with the ICP unplugged kinda like it was starting to hydro lock and then it starts and there is a TON of white smoke that smells like raw fuel. Other times it started ok. Any thoughts I have access to a snap on that I can monitor and look for things but it will take me a few days to get it. Also if itís randomly dieing will live data tell me anything or do I have to be looking at it as the symptoms are happening.. thanks in advance
__________________
My Rig - 2005 CCSB F-250 Lariat - Stock
Wife's Rig - 2016 Z71 Tahoe on 22ís
  #2
Old 05-22-2020, 04:43 AM
bismic bismic is offline
Sergeant
Member's Gallery
Default
The white exhaust smoke sounds like an injector dumping fuel. You can do a lot of damage to the engine if you drive it without addressing that issue.
The ICP might be an issue also, but the injector issue is a priority to resolve.
__________________
Lots of good stuff
  #3
Old 05-22-2020, 05:23 AM
Lieutenant
Member's Gallery
Default
That only happened 1 time when I had the ICP unplugged. After that I plugged it back in and it has started fine every time. No smoke at all.
__________________
  #4
Old 05-22-2020, 04:43 PM
Sergeant
Member's Gallery
Default
Not sure why the ICP sensor would cause raw fuel to be dumped, but sounds like it needs to be replaced (or the connector/pigtail needs replacing).
__________________
Lots of good stuff
  #5
Old 06-05-2020, 03:55 PM
Jmztransport84 Jmztransport84 is offline
Private
Member's Gallery
Default
My 04 would jerk at stop lights sometimes. I changed out icp sensor with oem one and new pig tail and it would still do it. I would disconnect it and be good but didnt like the white smoke at cold start ups. I recently found that my oil pressure sensor behind oil filter was hanging on by one strand. Ordered new pig tail and it's been fine since. I would check the wiring....
  #6
Old 06-05-2020, 06:07 PM
Lieutenant
Member's Gallery
Default
Ok thanks. I plugged my icp back in and since I did that it’s been ok. But I will definitely check the oil pressure sensor wiring
__________________
  #7
Old 06-05-2020, 09:00 PM
Sergeant
Member's Gallery
Default
The oil pressure sensor ONLY goes to the dash gauge. It is not even connected to the PCM. It plays no part in any engine operational strategy.
__________________
Lots of good stuff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
