Go Back   PowerStrokeArmy > Power Strokes > 6.4 Aftermarket
Reply
Thread Tools Display Modes
  #21
Old 01-13-2020, 02:23 PM
sixmassive's Avatar
sixmassive sixmassive is offline
Corporal
Member's Gallery
Default
I did a network voltage check and the data circuits are seeing 2.5-3.5v and 1.5-2.5v.
I don’t have access to the WSM, only caught a screen shot in a Powerstroke DR video.
  #22
Old 01-13-2020, 02:24 PM
Harley-6.4's Avatar
Harley-6.4 Harley-6.4 is offline
Private
Member's Gallery
Default
Did u try having Ford load a stock file?
  #23
Old 01-13-2020, 02:59 PM
sixmassive's Avatar
Corporal
Member's Gallery
Default
Tried to load a stock file, can’t communicate with PCM
Ran a manual network test and all modules failed. So maybe something within the CAN bus. Possibly still this PATS issue. Not sure how to test or if I should just buy a new transceiver and have keys programmed to it
  #24
Old 01-13-2020, 07:11 PM
Harley-6.4's Avatar
Private
Member's Gallery
Default
With the SCT programmer, does it tell you the current tune status, like what’s on the truck, Ex. Stock, Race, etc because of it can do that than there must be a connection of some sort to the PCM. Also you could b having a bad connection between the obd port and the PCM that has also happened to me in the past.
  #25
Old 01-13-2020, 08:00 PM
sixmassive's Avatar
Corporal
Member's Gallery
Default
With the new PCM there is no comms and reading mismatch of VIN.
The SCT will not read anything with the new PCM and will not even read DTCs or the strategy.
Tomorrow I’m going to swap the old PCM in and try to get communication. If I can then I know the new PCM needs to be returned. I dunno. It’s a ****sandy right now.
  #26
Old 01-14-2020, 05:28 PM
Harley-6.4's Avatar
Private
Member's Gallery
Default
Any new news?
  #27
Old 01-14-2020, 06:34 PM
sixmassive's Avatar
Corporal
Member's Gallery
Default
Not yet. Sending new PCM back. I installed the old and was able to read DTCs so there much be something wrong with how the new PCM was programmed.
  #28
Old 01-15-2020, 05:34 AM
wildbill963258's Avatar
wildbill963258 wildbill963258 is offline
Lieutenant
Member's Gallery
Default
The new one probably wasnt programmed to your truck, that's more than likely why it wasn't communicating. On the new trucks if you replace the pcm you have to take the truck to someone that can program the pcm to every drivetrain related system on your truck otherwise everything gets confused and wont know what to do so therefore won't work.
__________________
'96 F250 ECLB, 2wd, Auto, DIY CAI, 3"DP for exhaust. Sadly sold
'94.5 F350 CCLB 2wd ZF5 DIY CAI 3" DP for exhaust and stock tunes for now
  #29
Old 01-15-2020, 07:24 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
correct
  #30
Old 01-15-2020, 08:26 AM
Connor M's Avatar
Connor M Connor M is offline
Lieutenant
Member's Gallery
Default
buy a bcm for like 180 bucks online and drop the truck off with the truck at a ford dealer if that's an option. I believe they need to copy files off the bm while it's in the truck and then install the new one, and flash it back. I just went through this a few weeks ago.
__________________
2008 CCSB 6.4 Harley Davidson- PPEI Tuned, EZ Lynk, 4" Jamo Stainless Exhaust, Diet Coke, 35x12.5 Cooper Discoverer STT Pros- Down But Not Out
2008 CCLB 6.4 Lariat Land Yacht- H&S tuned, S&B intake, Diet Coke
2008 EC C&C F450 6.4 Work Truck- Build Loading
2003 RCLB 6.0 XLT- 260,000 miles, no name tunes, stock as can be
6.0 Dump Trucks- 350 and 450
VT365 Rollback
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
