Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #11
Old 01-13-2020, 10:59 AM
freddie's Avatar
freddie freddie is offline
Sergeant
Member's Gallery
Default
I guess I'm leaning towards ordering a 364.5 unless someone comes in with new info. Would love to see a dyno comparison between the 2.
__________________
97 CCSB
  #12
Old 01-14-2020, 12:14 AM
JCart JCart is offline
Sergeant
Member's Gallery
Default
Quote:
I’d call the guys at KC turbos they should have comparative data I’m thinking. Thought there was a post on here about both turbos on same truck for dyno data and real world towing anecdotal info. Will be interested in what you experience Freddie, keep us posted. For now I’ve just rebuilt my stoker with KC internals (their exhaust wheel, shaft 360 bearing kit and 1.0 A/R) and think it was a billet 6x6 intake wheel from Clay at RiffRaff. With newly installed FFD205/30s and Jelibuilt files spools up quick, will be interesting to see how long it can take it. I’m guessing I’ll be chewing on similar issue so will be good to know how you make out.
Cheers,
j
__________________
'97 F250 ECLB Tan White Tan Now ZF5 , 4:10s, D60, PMF 3.5 RSK, 37 Toyo RTs Anti sways front/rear w rear bags 5 blocks (184,000 Kms) DP, intake and 4 exhaust, FFD 205/30s, Hydra, E fuel.
Truck pix & Write ups
  #13
Old 01-15-2020, 11:39 AM
freddie's Avatar
Sergeant
Member's Gallery
Default
Thank you for the input. I called and talked it over with Irate also, and they too suggested the 364.5 so I ordered one.
__________________
97 CCSB
  #14
Old 01-15-2020, 12:46 PM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
Did you get the big one or little one?
__________________
I'm sweatin' like a wh*re in church here!
  #15
Old 01-15-2020, 12:54 PM
freddie's Avatar
Sergeant
Member's Gallery
Default
I got the 364.5/74/.91
__________________
97 CCSB
  #16
Old 01-15-2020, 08:17 PM
TMCCOY's Avatar
TMCCOY TMCCOY is offline
Sergeant
Member's Gallery
Default
The 364.5 is a great turbo for most normal uses. FWIW, the little one is more responsive and drives great with small injectors.
__________________
L99 CC SWB, 7.3, 4WD, 285/65-18, 3.73, Auto.
S364.5 SXE, PIS 175/80, T500, RR billet plenums, Fluidampr, Melling LPOP, 910 springs, S&B Intake kit, PHP Hydra, CNC HPOP lines & Quad fuel feed, 6.0 cooler, Built trans & Billet converter, Warn hubs, TrueTrac, PMF traction bars, Flo-Pro 4" exhaust, H&H tank mod.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
