New PMF product! Airbag/bumpstop tang ubolt top plates.
NotStock
Tucson, AZ
We are now offering our ubolt top plates with an Airbag/bumpstop tang option. This is intended for use with lift packs and eliminates the need for the hokey spacers that would otherwise be needed to make a bag or bumpstop kit functional. Our normal top plates retail for $49 a pair and this option adds $100. We will offer a 10% forum discount for the next 30 days on these as a promo! We have these instock and ready to ship!
http://pmfsuspension.com/Adjustable-Alignment-Pin-Ubolt-Top-Plates_p_33.html
Jomax
Arizona
You need to make an air bag setup that's quick release so you can go back to off-road mode with bumps stops. That would be sweet.
NotStock
Tucson, AZ
Jomax, have you seen the Daystar lower capture deal for overload bags that they make? If/when we make an overload bag setup, I will likely incorporate their capture into the kit.
Vader's Fury
Chesapeake City, MD
So I can use this top plate instead of the lower mounting plate on my helper air bags?
Just want to make sure I understand properly.
Will this work with a truck that is lower than stock?
NotStock
Tucson, AZ
Vader, likely these would not work for you. They are intended to be used on trucks with lift leaf packs, where the arch of the spring puts the ubolt top plate and in turn the top of the block lower than it normally would be with an oem leaf.
Jomax
Arizona
Yeah. I looked into that. My issue is the air bag will not survive off-road even with the cradle. This would be for a CARLI equipped truck. I've destroyed 3 sets of factory bump stops.
NotStock
Tucson, AZ
Gotcha. Some sort of semi quick release or a really long travel bag would be the ticket for ya then it would seem.
not even the carli longtravels will survive?
