Go Back   PowerStrokeArmy > Non - Specific > Suspension, Drive Train, and Tires
Reply
Thread Tools Display Modes
  #11
Old 01-14-2017, 07:06 PM
TLyons90's Avatar
TLyons90 TLyons90 is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by NEVRNF View Post
1st thing I see is it has a Gooseneck hitch. The overloads have extra leafs to handle the hitch weight. This tells me the truck towed heavy all the time. I had this done to my 99 when I was snowplowing and had a V box salter with 2 ton of salt in the bed all winter.
I agree the block is ugly. I would find a lift block from ICON or PMF that has the same height and still retains the ear for the bump stop.
I noticed the gooseneck as well, but it appears to still have factory paint on it from not having a ball put in. However I was told the guy was a pipe fitter so I believe he used the truck as a welding setup in the bed, there fore added weight and having the heavier duty overloads.
When people keep saying the blocks are ugly, what do you mean by that? I figured blocks were blocks even tho these don't have the bump stop ears on them. Thanks!
__________________
2013 F350 Lariat Dually
4" Diamond Eye Downpipe Back
SCT X4 W/ Tyrant Tuning
4.5" RCX Lift
RCX Dual Steering Stabilizer
  #12
Old 01-14-2017, 07:16 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
might just be the angle of the dangle but those blocks look like they are almost ready to collaps.. very cheap way to do a lift and not the safest.
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #13
Old 01-14-2017, 07:22 PM
General
Member's Gallery
Default
Aldo looks like they stuffed a couple add a leafs in there by the looks of the middle 3 springs being different colors.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Designed by Military Ltd
