Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 05-08-2018, 09:01 AM
rman rman is offline
Sergeant
Member's Gallery
Default 08+ Mirrors Q
getting ready to slap some 2014 mirrors on my 2003
quick q, these are power fold/Telo. What's the easiest/best way to do this?
Was thinking of cutting the factory pigtails off my 2004 mirrors and splicing them onto the new mirrors, then running new wires for the extra features.
Otherwise is there a source for the factory door-side pigtails, to splice into my truck instead?
Thanks!
  #2
Old 05-09-2018, 08:11 AM
Sergeant
Member's Gallery
Default
nevermind. my google-fu kicked in. Found you can get the connectors and pins for dirt cheap.
Now my OCD wants factory switches.
Wish my OCD would work on my oil leak and drivetrain squeak.. or hazed headlights. balding tires... f650 lower dash... helper bags... more lift... 20x12s...
  #3
Old 05-10-2018, 10:52 PM
powerlifter405's Avatar
powerlifter405 powerlifter405 is offline
Major
Member's Gallery
Default
Got any links to share for the wiring/switches?
Having the fancy mirror options on the older trucks would be a nice upgrade if not pricey.
__________________
05 original factory head gaskets and TTY bolts until 302k Did ARP 1 bolt at at time@ 250ftlbs, no egr Redhead steering gear KC 63.5mm... factory exhaust w/ no meow/factory intake all factory stuff, rancho 9K's adj, PM w/ questions
  #4
Old 05-26-2018, 10:00 PM
Sergeant
Member's Gallery
Default
I gotta dig them up, I post up when I do.
Just scored a new/takeoff switch panel with both Adjust/Fold and Telo switches on ebay for $30ish.
The factory adjustment switch can be removed, and the hole trimmed bigger to fit the new switch. I plan to mount the Telo switch on the dash under the headlight knob, right next to the adjust/Fold switch.
Truck is definitely neglected lol. Have a F650 dash, helper bags, new CPS orings, new EGT sensor, sway bar bushings, and a new bumper waiting... needs a brake job and I have a fuel leak during startup when temps dip into the low 30s.... it never ends!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
