2012 to 2014
sagebel
East Chatham, NY
I just picked up a 2014 and traded the 2012. I returned the '12 to stock before I traded. I only want to run *** on tuning with the '14. My Minimax does not show an option to switch to a 2014 truck, the only 6.7 option is '11-'12. Is there a way to get updated tuning? If not, I have a Minimax for sale.
Horsemover
If it's an original H&S race tuner than I think your out of luck. I think the later "knock offs" support up to 14. Hopefully somebody can help you out.
ABMax24
Grande Prairie, Alberta, Canada
Mine supports my 2014, I found the Minimax files online to download straight to your SD card, hopefully it should work, my tuner is part #7009, not sure what yours is. My guess is your tuner is just missing the correct files to function properly, it needs the Ford13 folder in particular to work. But backup your current sd card to your computer and copy ALL these files to your card replacing your current ones. Hope this helps! https://app.box.com/s/htz6svj6w7el0w7ic5t382lsciilwpu9
