05 Front end conversion headlights
Copracr
I bought my truck with a 05 front end on it and the low beams are really dim. The blinkers provide more illumination. Does anyone have a wiring diagram for the 05's that I can use to check out the wires and be sure they're hooked up right?
Thanks
Copracr
Well, in case anyone wonders...
The PO wired them up wrong so the low beams where grounded through the high beam circuit. The high beam wire supplied power through the bulb ground and of course grounded through the high beam circuit too. Result was good highs and dim lows. Switched 2 wires and all is happy.
Copracr
I'm just happy i can see the road without high beams now, oncoming traffic is prolly happy too.
