Well S***
Cypress, TX
So let's place bets on what is happening. Looks like motor is eating itself. Went to replace lower pan gasket to day only to uncover issues.
Cypress, TX
These last two pics have some crap in them that was already in the strainer on our oil drain cart.
So in the pan I found a pure pieces of black rubbery material. Not too large, then we found what looks like a part of a valve stem seal. But since I did not notice anything until I dumped the pan and looked at the pick up I am unsure if that rubber piece was in the pan.
Everything for the most part is super thin which makes me think bearing but nothing was discolored and no unusual noise.
DEEZUZ
NO PUKESTERS
NWI
Yup. I'd be quoting a new motor if that came through the shop. I just did one with much less in the pan but about 3x as much in the filter.
Mesa, AZ
Had one of my good fleet customers have the same scenario. Doing a lower oil pan, found the same chit. Cant see anything with the design of the upper pan. He decided to keep an eye on it, and do oil analysis to keep an eye on if it was getting worse. He made it about 2 months/15k, before it finally chit. It was popping thru the intake, huge clouds coming out of the oil fill and intake, and knocking pretty bad. Didnt tear it down to see what happened, but ended up putting a drop in motor in.
co04cobra
WV
I've got a few used engines if you end up wanting to explore options that way, shoot me a pm.
DEEZUZ
NO PUKESTERS
NWI
It's going to be a cam/lifter failure.
I thought we were done with this after 6.0/6.4 but it's still alive and well...
Jonnydime
We just put a motor in our 12’ 550 that ate a lifter at 148k miles. 14,000 hours though.
redneck1
Nor Cal
That's impressive! Average 45 mph on 14,000 hours would be 630,000 miles. Wouldn't complain about that..
Sent from my iPhone using Tapatalk Pro
Cypress, TX
This is Morgans old single cab truck I bought from Cody back in September.
So the body has about 85K miles but the motor is built and I would suspect it don't have much for miles on it considering what it was built for. I would guess that it is the original lifters and cam, I cant find anything that says any different.
Funny part is not knowing an abundance about these engines my first thought was cam/lifters because I had a built gas motor truck that had a bad cam core that started flaking apart.
I was waiting on a piece to fix the waste gate and piping so I could start having fun again. Guess it will have to sit around for a while with the amount I have going on. When I get the 2 post lift re-positioned and hooked back up I guess i will go ahead and pull the cab.
CATDiezel
So.... How many miles have you put on it since you bought it from Cody?
Sucks when stuff like this happens.
bigrpowr
<How I Fly
Administrator
ive had 2 built motors $hit the bed. one totally my fault , one had a forged piston grow. sucks for sure.
Cypress, TX
From the picture I have of the odometer when I registered it to now about 337 miles.
Even if it was happening when Cody had it he would have never known because nothing came out when draining the oil. It was all in the pan.
Just reminds me of old times and why I told my self I was not doing performance stuff to my daily drivers anymore. I fixed the AC, then on thanksgiving I blew the metal flex connector to the waste gate and now this. Good thing it's not my daily.
bigrpowr
<How I Fly
Administrator
i wish morgan was around so i could bust his balls :(
Six_Sloww
Southeast MI
Hate to see that... The pan was off the truck MAYBE 3000 miles ago to put the drain for the atmo turbo in and I've done 2 oil changes since then and never saw anything metallic. I never chopped a filter, but never had a reason to.
Six_Sloww
Southeast MI
Possibly shavings from drilling and tapping the upper pan? Obviously you would hope that stuff was properly cleaned up but I'm just thinking of scenarios that are less serious than bearing or lifter failure.
The heads were just off too, so no signs of anything at the time but I can't say if the lifters were looked at or not.
