Built 7.3 motor for sale
boosted365
Motor was built by Carson Stauffer Diesel.
It has a main stud girdle, Crower connecting rods,ceramic coated pistons.
Crower valve springs and pushrods, mild port work on heads, fire ringed heads.
Stealth stage 2+ High Pressure Oil pump.
400cc injectors with 400% nozzles.
I have 13,000 miles on this motor.
Asking 8,500
717-250-3924
DieselDC
O man good luck with the sale. Some good parts in there! That's high dollar for sure. Bump!
Magnum PD
VA
Depends on tunes, turbo, elevation, trans, tires, compression, power adders, so and so
Maybe around 750 ish
I too would be interested in the short block if you deside to go that route
Sent from my VS987 using Tapatalk
