Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 04-13-2018, 05:59 PM
panteramatt panteramatt is offline
Private
Member's Gallery
Default high fuel pressure after blue spring mod
My fuel pressure is at 84 psi idle. Is that too high? I read 75 should be max. Is that high enough to blow the injector o-rings?
  #2
Old 04-13-2018, 07:55 PM
Phaney Phaney is offline
Corporal
Member's Gallery
Default
Quote:
Interesting. Getting ready to do the blue spring mod to mine tomorrow. Did the hutch and harpoon mod today. Man my filters were dirty. Truck sounds smoother now to.
Sent from my SM-G955U using Tapatalk
  #3
Old 04-13-2018, 08:19 PM
Decker's Avatar
Decker Decker is offline
Sergeant
Member's Gallery
Default
Did you buy the spring from Ford or aftermarket? If aftermarket, they state blue spring but some have a higher psi rating. I got one before from Rudy and it set me about 85. It stated factory updated spec but was not.
They sent me another one to lower the pressure and it was to soft. I gave up and went to Ford and haven't had a issue since.
__________________
06 F350 CCSB King Ranch - For Sale
Studded, *******, upgraded banjos, blue spring,
6.7 fuel pump with sump, swamps 58v ficm
4in turbo back, coolant filter, guages, CAI,
SCT w/ IDP & TSD tuning & PHP ficm tuned
04 F250 CCLB XL - Sold
  #4
Old 04-14-2018, 05:36 AM
Private
Member's Gallery
Default
One thing I just noticed is I must have slightly bent the pipe coming out the side of the regulator when I removed the cover. Could this cause pressure to raise?
  #5
Old 04-14-2018, 09:47 AM
Corporal
Member's Gallery
Default
Yes. I bought mine from Rudy's also. I guess I'll wait till I get my fuel pressure gauge sensor installed before I change the spring so as I can keep an eye on the pressure. Just waiting on my adapter elbow to get here.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
