Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 08-15-2012, 03:55 PM
faster6.0's Avatar
faster6.0 faster6.0 is offline
Member's Gallery
Default 6.0 Important Ford Part Numbers
Mods a sticky for this one would be good.............
6.0 Power Stroke Part Number Part Price
High pressure Oil 6E7Z-9A332-B Up Dated Stand pipes $102.00
4C3Z-9F838-A Late Build ICP sensor $99.00
3C3Z-9F838-EA Early Build ICP sensor $99.00
5C3Z-12224-A ICP Pig tail connector $49.21
3C3Z-9C968-AA Early Build IPR $179.10
5C3Z-9C968-CA Late Build IPR $159.91
3C3Z-9A543-AARM Early Build 6.0 HPOP
4C3Z-9A543-AARM Early Build 6.0 HPOP
5C4Z-9A543-A Late Build 6.0 HPOP
5C4Z-9A543-B Late Build 6.0 HPOP
4C3Z-9B246-F STC Fitting
W302908 Up Dated Dummy Plugs
Injectors 3C3Z-9E527-ECRM Early Build Injector $400.00
4C3Z-9E527-BRM Later Build Injectors $400.00
FICM 4C3Z-12B599-ABRM Fuel Injector Control Module
Fuel Pressure Regulator 3C3Z-9T517-AG Fuel Pressure Kit $51.70
Gaskets 3C3Z-9433-BE Intake Gasket Set $87.00
W302725 PCV O ring $3.88
3C3Z-9T514-AD Turbo mounting Kit $12.97
5C3Z-6079-B Head Gaskets $135.30
3C3Z-6051-CA Early Build Head Gaskets
4C2Z-12A690-BA Glow Plug Harness L
4C2Z-12A690-AB Glow Plug Harness R
6C3Z-9448-A Exhaust Manifold Gasket
Coolant System 4C3Z-9P456-AF Late Build EGR Cooler
6C3Z-8A080-B Degas Bottle
9C3Z-8101-B Degas Bottle Cap
3C3Z-6A642-CA Oil Cooler
Base Engine Oil System 3C3Z-6A642-CA Oil Cooler Kit $213.99
3C3Z-6C683-AB Screen under oil cooler $6.78
3C3Z-9T516-A Updated Turbo Supply $76.96
6C3Z-9T515-A Updated Turbo Drain $20.90
3C3Z-6675-AA Oil Pan
3C3Z-6710-BA Oil Pan Gasket
3C3Z-6626-AA Pick Up Tube O Ring
W300002 Oil Pan Bolts Short
W300014 Oil Pan Bolts Long
PM-13-A High Temp Coating
Turbo Charger 5C3Z-6F089-BA VGT solenoid
3C3Z-6K682-CCRM Turbo Assembly
3C3Z-6P854-DA Turbo Up Pipe
5C3Z-9G489-AARM 04+ CHRA
6C3Z-6C640-AA Metal Cold Side CAC Tube
Filters FD-4616 Fuel Filters $49.49
4C3Z-9601-AA Air Filter $50.73
FL-2016 Oil Filter $19.14
6.4 banjo Bolt kit W302472 *2 Bolts $9.92
W303659 *4 Washers
  #2
Old 08-15-2012, 03:56 PM
faster6.0's Avatar
Member's Gallery
Default
6C3Z-6C640-AA Metal intercooler pipe into motor
  #3
Old 08-24-2012, 01:59 PM
Spindrift Spindrift is offline
Lieutenant
Member's Gallery
Default
__________________
'12 F350 CC DRW KR
H&S tuned
Redwood 36FL
  #4
Old 08-24-2012, 04:21 PM
colo_dually colo_dually is offline
Sergeant
Member's Gallery
Default
Nice list, thanks for posting.
__________________
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
  #5
Old 09-09-2012, 01:29 PM
faster6.0's Avatar
Member's Gallery
Default
heres another great link for FICM and Injector diagnosis.
http://www.fordtechservice.dealercon...FICM_Guide.pdf
  #6
Old 01-08-2013, 02:11 AM
harrisford harrisford is offline
Corporal
Member's Gallery
Default
How about a unision ring number and blue spring upgrade number? I dont have either but they would be handy
  #7
Old 01-08-2013, 06:51 AM
91turbogsx's Avatar
91turbogsx 91turbogsx is offline
Major
Member's Gallery
Default
Upgraded fuel pressure regulator kit (with cover): #3C3Z-9T517-AG
Fuel Pressure Regulator "Spring and Reseal Kit Only": #6E7Z-9C165-B
Regulator cover gasket only: #3C3Z-9C065-AA
Unison ring: 3C3Z-6C885-A
__________________
'02 F-350 4x4 Black RCLB
'08 F-350 4x4 Blue/Silver CCLB Shop Truck 11.89@114
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
