Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 03-26-2018, 10:09 AM
atc500 atc500 is offline
Private
Member's Gallery
Default Contribution balance cylinder #7
Just did studs one at a time dummy plugs stand pipes ,updated STC fitting and an egr ****** on a 2005 and now injector in cylinder 7 isnít firing it passes a buzz test fine ficm was recently redone I double checked it and the harness truck has 63k Miles is it possible the lack of oil from draining the pump and rails wiped the injector out? Iím stumped on where to go from here
__________________
2007 f350 Single cab,studded,155/stock sticks, atlas40 ficm, Gear Head tunes, Barder STG2 Turbo, 3.5"Down Pipe
  #2
Old 03-26-2018, 10:25 AM
Petro's Avatar
Petro Petro is offline
Major
Member's Gallery
Default
Unplug that Injector and check the pins on both the male a female sides of the plug. Sometimes they can be pushed in and cause issues. I've seen that happen more than once. If it ran fine before, it's more than likely an electrical issue somewhere.
__________________
Tow Rig/ Daily Driver
06 F350 CCSB 4x4 6.Blow ZF6, 220k - Warren Tuned, 190/100's, Powermax, RR, Ported Manifold, Fass 200, Water/Meth
Pulling Truck
05 F250 CCSB 4x4 6.Blow 5r110, 230k - Hybrid 250/100's, S369, RR, Fass
Past: Several 7.3s and a few 6.4's
  #3
Old 03-26-2018, 11:40 AM
Private
Member's Gallery
Quote:
I tried that and both plug and prongs looked fine I even tried switching #7 plug with #5 and no change still missing even swapped out the injector harness with a spare and throws the same code
__________________
  #4
Old 03-26-2018, 01:53 PM
Petro's Avatar
Major
Member's Gallery
Default
Well if you did all that and it's still missing on the same cylinder, that Injector probably sh!t the bed.
__________________
Pulling Truck
  #5
Old 03-26-2018, 02:40 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
Ficm plugs fully seated?
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2011 International Duraturd 4300 Mechanics truck
2001Tdi Jetta 5 speed
  #6
Old 03-26-2018, 09:08 PM
webb06's Avatar
webb06 webb06 is offline
Colonel
Member's Gallery
Default
You sure itís not mechanical? Like a push rod popped out or a bridge isnít fully seated?
  #7
Old 03-27-2018, 06:00 AM
Private
Member's Gallery
Default
Quote:
I donít see how they were never pulled
__________________
  #8
Old 03-27-2018, 08:25 AM
Petro's Avatar
Major
Member's Gallery
Default
Swap #7 Injector with #5 and see if the miss follows. That will give you a definite answer weather it's the Injector or electrical.
__________________
Pulling Truck
  #9
Old 04-09-2018, 10:13 AM
Private
Member's Gallery
Default
Just letting everyone know I pulled the #7 injector and the spool valve had a piece of plastic jammed in it looks like a piece of clip from injector but we never pulled them so not sure how it got there but sheís up and running now Thanks for the input
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
