Go Back   PowerStrokeArmy > Non - Specific > Project Forum
Reply
Thread Tools Display Modes
  #1001
Old 05-29-2016, 09:15 AM
Vader's Fury's Avatar
Vader's Fury Vader's Fury is offline
Colonel
Member's Gallery
Default
So what makes you suspect problems with the pump?
__________________
Robert
2003 F-350 CCLB, Frame off restoration in progress
2002 F-250 ECLB, Parts hauler
2002 Excursion, Twin hauler
  #1002
Old 05-29-2016, 10:47 AM
Cutting-Edge Diesel's Avatar
Cutting-Edge Diesel Cutting-Edge Diesel is offline
Sponsor
Member's Gallery
Default
We can't get the lope out of it and it doesn't free rev right. It's running fine under load but they want to look it over.
  #1003
Old 05-29-2016, 11:32 AM
WhiteMamba_Scorpion's Avatar
WhiteMamba_Scorpion WhiteMamba_Scorpion is offline
Major
Member's Gallery
Default
Don't most big mechanical pumps lope until they're under full load? I thought that was just the nature of the beast. Pretty much every pulling truck lopes while spooling... but I will say they don't quite lope as much as your 7.3 does
__________________
Pete
2012 CCSB: 766/1552 SOLD
  #1004
Old 05-29-2016, 11:47 AM
Sponsor
Member's Gallery
Default
Quote:
Yes to a point. There is a bumper screw on the back of this pump that dampens the governor arm and will make it idle better.
  #1005
Old 05-29-2016, 03:52 PM
Major
Member's Gallery
Default
Ahh ok. Either way its gonna be gnarly once it's dialed in.
__________________
Pete
  #1006
Old 05-29-2016, 04:17 PM
CATDiezel's Avatar
CATDiezel CATDiezel is offline
Major
Member's Gallery
Default
Quote:
It's basically the same as thinking: electronic PID LOOP tuning.
The gain is too fast and the proportional is not dampening.
In the case of a mechanical pump it will be in the flyweights. Probably too light or the flyweight a are simply stuck one or the other.
__________________
2015 F250 Platinum CCSB 4x4
S P A R T A N tuned
Toyo OpenCountry AT2 35/12.50/20
BMF Novakanes
Justin M.u.d.g.e.
  #1007
Old 05-29-2016, 04:26 PM
CATDiezel's Avatar
Major
Member's Gallery
Default
That's largely to do because the injector is so big in conjuction to the lack of a BIG timing advance assembly it's next to impossible to control the idle. It's basically fuel on fuel off repeatedly.. the lope. It can be brought under control but not easily. Much easier you control at higher rpm when the weights in the governor have some momentum behind them.
That's going to be the trick to getting this yellow wagon to idle somewhat under control is the perfect balance for weights on the AFr. Too light and they respond like uncontrollably. Too heavy and spool up becomes an issue and he will have a drowning affect once he leaves the line and it shifts one time.
If you will notice a 14liter+ engine does not have the problem of loping and spooling like a "small engine" does. And that's because they have a AFR weight assembly as big as a quart size paint can lid.
__________________
S P A R T A N tuned
BMF Novakanes
Justin M.u.d.g.e.
  #1008
Old 05-30-2016, 05:41 PM
CATDiezel's Avatar
Major
Member's Gallery
Default
Small correction on my own wording. When dealing with the AFR it works in conjunction with the timing advance unit with is dynamic on large engines... more so than small engines. The TA is the more proportionated weights, where a small engine struggles in this area.
__________________
S P A R T A N tuned
BMF Novakanes
Justin M.u.d.g.e.
  #1009
Old 06-14-2016, 07:45 PM
Sponsor
Member's Gallery
Default
Last time you will see it yellow
  #1010
Old 06-14-2016, 09:24 PM
shmoozer's Avatar
shmoozer shmoozer is offline
Major
Member's Gallery
Default
What have you decide on color wise?
__________________
"I have 2 speeds, full throttle and reverse....even reverse is pretty fast" -South Mouth
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
