The 2011-16 Leveled Super Duty Thread
Squat and Poot
Houston, TX
There is a generic thread with pictures of all year models but I wanted to start a thread for the 6.7 guys up to the 16 model.
Post your leveled trucks and if you'd be so kind to include wheel/tire and suspension items for others to reference in the future. let's set the limit from 2.5-3.5" front to a 4" or 5" block since most lift kits start at 4.5 inches.
I'll go first.
2.5" Carli Coils
Carli tuned Fox 2.0s, PMF dual steering with Fox's
Stock rear
Stock wheels and tires
Tom@BigTimeKustomz
Bayville, NJ
2013 F350 CC/LB
2.5 ReadyLift up front
5" rear block
Bilsteins at all 4 corners
20x10 Fuel Couplers
35x12.50 Toyo A/T's
UNBROKEN
PMF 3 link, traction bars, dual steering stabilizer with Fox 2.0's and 4" rear block, Icon 2.5" coils, Fox 2.5 resi's on all 4 corners and Hellwig sway bars front and rear. Also has a Ready Lift track bar drop bracket. Soon to have PMF drag link and a few other things.
22x10.5 with 325/50/22 Toyo's
DoubleLung
Just picked her up Friday night. 2.5" leveled with stock wheels and 37x12.50r20 nitto trail grapplers
Mechcont
BDS leveling kit with BDS radius arms, Fox Resi all around and BDS 6" leaf springs with the blocks removed (rear is 2" higher) and 35x12.5x20 Toyo's .
jwalk09
VA
2.5" Carli coils with 4" block in rear
Carli adjustable track bar
295/60/20 terra grapplers as of now
Sterling6.7
Nothin as fancy as the rest, but it's mine. Up 2.5" in the front, stock blocks in the rear.
wjamesm
Bellefonte pa.
How does it set with the 2 1/2'' in the front and stock blocks in the rear ? Is the truck level or high in the front . I have a 2 1/2"" Icon i am going to install in the spring and wonder if i need taller blocks than the stock F350 blocks
Sterling6.7
It is on a slight incline in the photo. On the level, it measures 3/4" high in the rear. It's on the correct side of level for me. I'm not a fan of the draggin ass look.
Yellow1000
eastern MO
Agreed there . I don't like the ass being to low. I'm stuck on either a 2.5 front kit vs a 1.5 front kit. I just don't want the front higher then the rear. Unless i go with a 5 inch block in the rear.
1stock13
Has anyone tried to ready lift spring spacers for the 1.5 inch front lift? I like the height in the rear, but I could use an inch up front.
Squat and Poot
Houston, TX
A lot of guys on here use Icon or PMF bottom mount coil spacers. I have a set of 1" PMF spacers just in case I ever need a little more lift
