Polishing aluminum wheels- tips/tricks needed
slc6oh
Utah
So I’ve let my wheels go a little long and they look like chit.
Started polishing today. About an hr with a mother’s cone and polish I got the one I did today looking a lot better. But still isn’t perfect.
What tips/tricks y’all got? I feel like there’s gotta be an easier way.
Before
After
mandkole
Northwest
They look good. I use the power cone as well. I sometimes use some 1500-2000 wet paper to smooth the surface to allow quicker cleaning. I do my 8 spoke 20s twice a year and it takes about 30-40 mins per wheel.
slc6oh
Utah
Would like 0000 steel wool with soapy water be good to get the top rough layer off?
ckrueg
Belding MI
I did the power ball with the mothers billet polish. It took about an hour per wheel. I cleaned them good first, then did about a third of the wheel at a time. I was really happy with the results.
107stroker
I use a product called white diamond and the power cone. Seems to work better than mothers w less work.
mandkole
Northwest
. The wool doesn't concentrate enough on corrosion and the shallower scratches from the paper are much easier to polish out. I'll just tear a small piece to work the area. My 20s were stripped/raw as well.
Pockets
Villa Rica, Ga
Good cleaning, 2k grit wet paper, a power cone with White Diamond. So far so good just a little time...
junglejoe
Mo
I wet sand mine.. Then get a grinder with a 8 inch polishing wheel and brown bar compound.. MIRROR FINISH. Might be a little over board.. But it works.
Joshf250
What are you guys using to strip the clear coat off of your wheels? I have a set of 5 spoke 20”s that I’m wanting to do this to. And has anybody put clear coat on the wheels after being polished?
mandkole
Northwest
Lots of Kleen Strip jelly, then sanding and polish. That’s a job I won’t be doing again haha. They turned out good but takes maintenance.
RascalMafia
#hashtag
Super Mod
Middle GA
Best thing I have found is Adam's metal polishes.
Aircraft stripper to remove the clear.
RascalMafia
#hashtag
Super Mod
Middle GA
This is probably a dumb question, but why remove the clear?
Just a guess but probably peeling. Best bet is strip, polish to mirror, clear, ceramic coat. Or if you want to skip clear, ceramic coat.
Polishing metal sucks ballz.
Sent from my SM-G960U using Tapatalk
