Locked Out
golfpro2301
I am selling my 2010 6.4 and its been sitting for the last month. Went to get in and start it today to let it run and key fob and door code wont work as if the battery is dead. The key will go in the lock but wont turn. Any way to get the hood popped open to hook up battery to get power to locks?
My09Ride
Central Pa.
Just wondering? My thoughts. Can you reach the starter cable without taking the fender liner out, and will that hit the batteries w/out the key being on??? That's why I didn't share??? I'm dumb!
DEEZUZ
NO PUKESTERS
NWI
Well, starters are changed from the bottom, so there is plenty of room to get a charging cable clamp in there to get to the cable
eng53ine
Ohio
Oil the lock good and turn the key back and forth as another option.
Line8
Is the key hole frozen with ice?
Is there debris in there?
Both those can be solved and would be your easiest route in.
