Go Back   PowerStrokeArmy > Power Strokes > 94-97 Tech
Thread Tools Display Modes
Old 10-15-2017, 10:27 AM
ghohouston's Avatar
ghohouston ghohouston is offline
Member's Gallery
I bought a new napa slave cylinder, non bled. Hooked the old line up to the new slave. Took one of those parts washer guns, not sure on real name, but baiscally an air blower with a suction port and an on off valve. Mine has a barb with a hose on it. I removed the bleeder screw on the new slave, made sure the reservoir was full, and turned the valve on with the suction hose over the bleeder port. Took a few minutes, but was pain free, and easy. Once i got fluid coming out, put the screw back in, and installed the slave. A few pumps of the clutch pedal, and all was good.
1997 F350 SRW CCLB 4x4 ZF5 7.3
2011 International Duraturd 4300 Mechanics truck
2001Tdi Jetta 5 speed
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
