Go Back   PowerStrokeArmy > Power Strokes > 94-97 Tech
Reply
Thread Tools Display Modes
  #1
Old 11-02-2017, 05:41 PM
littlerobert1983's Avatar
littlerobert1983 littlerobert1983 is offline
Private
Member's Gallery
Default Fuel tank gauge not working completely fue reads empty
I have ******d the rear tank due to having auxillary tank I also removed the selector valve. What are the colors of the wires to keep the front tank gauge working on a 95 powerstroke 7.3.
Sent from my SM-S920L using Tapatalk
  #2
Old 11-02-2017, 05:46 PM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Well happened to the 30 other threads talking about this? Lol
Sent from my SM-G892A using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #3
Old 11-02-2017, 06:01 PM
boggerr's Avatar
boggerr boggerr is offline
Sergeant
Member's Gallery
Default
http://powerstrokearmy.com/forums/sh...ad.php?t=79709
Was answered here already
  #4
Old 11-02-2017, 08:47 PM
Private
Member's Gallery
Default
Quote:
Originally Posted by boggerr View Post
I've done the jumper wire and it reads empty even after I pout fuel into tank by the gallons
  #5
Old 11-03-2017, 07:49 AM
jschildm's Avatar
jschildm jschildm is offline
Sergeant
Member's Gallery
Default
If it was answered in a different thread, and the solution didn't work, then just put that in the same thread so it's easier for people to read back through what all has been tried, and what the results were. It will actually help you get better results faster than starting a new thread every time you try something different. I am not trying to be mean, but I think you could get help faster if you tried to keep all of the work on a subject in the same thread.
__________________
1997 F350 CCLB, 3" DP to 5" Straight Pipe, DIY Intake, 6.0 Tranny Cooler,Adrenaline, Irate Electric Fuel, Matt's Tunes and SD Seats ... IC and H2E sitting in the garage.
  #6
Old 11-06-2017, 06:52 PM
zilla68's Avatar
zilla68 zilla68 is offline
Major
Member's Gallery
Default
plug selector back in, much easier
__________________
Thanks
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
174k
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels 60psi
3:55 gears
Automatic with billet convertor, tugger and alto discs
******** Tunes and these are AWESOME
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
new mechanical pump
pyro, boost and trans temp gauges
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
