Turbo LSX build
Paris/Lebanon, TN
So it's been awhile since I've been active. Sold my built 6.0 and bought a RCSB Silverado. It had 110k on the little 4.8ls.... The guys from Boost Addicts and I immediately pulled the motor to start the turbo build. We started with a complete rebuild, custom grind 228/234 comp cam, LS6 intake manifold, upgraded valve springs, upgraded rockers. We did all of this while I was on leave and got the motor back in and running the night before I left to head back out..... the little 4.8 hits a lick now! Since I've been back in Iraq the guys at Boost Addicts ordered the 78mm turbo kit complete with everything along with a set of 80lb injectors, new fuel system, AEM wideband. Should be right around 600rwhp and will be looking for mid 6's in an 1/8th. I return home in April so we'll see what it can do.
BilletGarage
Minnesota
Sounds like a sweet build! I have had LS fever for a while now. A big inch twin turbo iron block build is on my bucket list. Post some pics up when you get a chance.
