Go Back   PowerStrokeArmy > The Bunker > Dyno Forum
Reply
Thread Tools Display Modes
  #11
Old 02-12-2016, 08:23 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
Originally Posted by *******DieselTech View Post
6th gear, with as much loading as the truck will stand.
4th and 5th gear pulls will generate artificially low numbers on these trucks that do not accurately reflect track times.
The ECM needs a slower dynamic engine speed condition (additional load) for many of the control loops to accurately portray real world conditions. Mainly, the lack of aerodynamic load on the dyno. They are much more sensitive to this than the 6.0 or 6.4.
so what RPM is ideal to start the pull at?
  #12
Old 01-12-2017, 08:12 AM
1800bigk 1800bigk is offline
Corporal
Member's Gallery
Default
Headed to dyno my 6.7 soon too, what rpm can we run this engine up to? I have stock internals.
  #13
Old 01-12-2017, 08:49 AM
Dzchey21's Avatar
Dzchey21 Dzchey21 is offline
Super Moderator
Member's Gallery
Default
Quote:
Usually we start at 1800-2000 on a stockish turbo truck and put it in 5th manual to load it the hardest. that way you have some time down low to build boost.
6th Gear pulls will net the highest HP usually but like stated a 3.55 truck in 6th reving all the way to 3500 or more is very fast. We have seen a couple tires come apart on the dyno and it is not a good thing. totally trashes bed sides when it happens.
That being said we have never seen a good looking tire that came apart. They are usually some cheap or weathered tire that comes apart. We have had plenty of Toyo MTs passed 150... yikes
__________________
2017 F-350 DRW Platinum stock for now
1979 F-150 6.0 Swap in progress, 86mm LP turbo, 04 frame and interior
  #14
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
Quote:
3500 is about all that you want to run it up to. 3700 would be ok
__________________
  #15
Old 01-12-2017, 01:28 PM
Corporal
Member's Gallery
Default
Quote:
great thank you, I noticed my truck shifts around 3500 rpm but noticed the tach redlines at 4k so was curious.
  #16
Old 01-12-2017, 02:23 PM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
They will rev to 4K on their own but it starts cutting fuel before that.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
