Go Back   PowerStrokeArmy > West Point > The Library > 7.3 Tech & FAQ
Reply
Thread Tools Display Modes
  #51
Old 10-22-2012, 09:27 PM
JD3020's Avatar
JD3020 JD3020 is offline
Colonel
Member's Gallery
Default
A full on test stand would be nice, but using an air supply to test clutch packs is what i was going after.
__________________
Jimmy
2014 F-250 XLT, 68k, H&S IC pipe, Tyrant tunes and deleeted
97 F-250 ECLB 7.3/E4OD/4wd, 215k miles: FFD 250/200%'s, Swamps IDM, built trans. Built and tuned by me
01 F-450 crew cab, XLT ZF-6 7.3: tuned, intake, exhaust, 310k miles
05 Jeep Liberty diesel, tuned, EGR deleet
  #52
Old 10-22-2012, 09:39 PM
TARM TARM is offline
Major
Member's Gallery
Default
BTW I found a good PDF that was put together from the writeup[ Racer X originally did ona forum back when he sold all the parts kits to do rebuilds. The one I put up back on page one did not have the pics as they had been removed (the links were broken) . This has all the pics with the proper instruction set to each picture. While there are a number of differences between the E4OD and 4R100 they so close this will be helpful to all.
This is a PDF and to not kill people on page two with all the pics uploading I will just post the link and have it uploaded to the PSA web servers.
__________________
01' Excursion (forged): ********'s tuning, GTX4294r-1.15t4, Nate's Stage 5 Firehoses 465cc/200%, Stealth's SP1, ARP Studs, 910's (shimmed), DI Pushrods (SAE 4130 CM), Full Custom Fuel System, aFe-Big Boost, DE 4" Exhaust, BTS Trans, 99'-04' V code front/08'F code rear spring swap, PMF 4"Hanger-Shackle kit/5"Rear Blocks, Custom Valved Blistien's, Rear Sway bar, Bushwhackers Cut-out Flares, Fuel Hostage 20"x12" Black Wheels, Interco M16 40"x14.50"x20" Tires
  #53
Old 10-22-2012, 10:45 PM
4.0l sahara's Avatar
4.0l sahara 4.0l sahara is offline
Major
Member's Gallery
Default
I'm not the man in the shop building transmissions but I know Jim the builder always just puts air to it real fast to check the packs and that is it. I don't see the need to go any farther than that.
__________________
Champion Transmission & Diesel Performance
Phone-203-931-6178
old antiquated pos with some crap bw s467 fmw,irate rr/full fuel system,full force 350/200 injectors,irate SS gated t4 mount,arp studs,smith bro push rods,comp 910's, gen3, twin ipr's, ams1000 with co2, champion built 4r100,tuned by bill, etc
  #54
Old 10-22-2012, 11:37 PM
Major
Member's Gallery
Default
Makes sense to me. I am sure no authority on the subject thats for sure. I am happy if I could take one apart and put it back together and not have a box of parts still left over
__________________
  #55
Old 10-23-2012, 06:03 AM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
Do you have to limit air pressure? I seem to remember that being the case.
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
  #56
Old 10-23-2012, 07:01 AM
Major
Member's Gallery
Default
No I wouldn't worry 150psi isn't going to do any harm.
__________________
Phone-203-931-6178
  #57
Old 01-07-2013, 02:35 PM
SDstroker's Avatar
SDstroker SDstroker is offline
Lieutenant
Member's Gallery
Default
Good write up!
__________________
Mark aka opieg01
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6, 5" full traction lift
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
