Go Back   PowerStrokeArmy > Non - Specific > Project Forum
Reply
Thread Tools Display Modes
  #1
Old 08-31-2016, 04:26 PM
Vader's Fury's Avatar
Vader's Fury Vader's Fury is offline
Colonel
Member's Gallery
Default Dump/Flatbed with a gooseneck hitch
So I have a F-450 that I am putting together that I would like to setup as a flatbed/dump bed by using removable sides. I also would like the ability to tow a gooseneck trailer with it.
Here is my thought process. I am going to be mounting it on a 05 F-450 CC chassis. I will build a heavy duty flatbed with a fixed front bulkhead. Set it up with short metal sides that are removable for when I want just a flatbed. Also will set it up with a tailgate style rear to give me some extra reach when dumping since the bed will have to be kept short to allow for towing the gooseneck.
I will be using a scissor lift that actually came off of a International 4600 so not worried about lift capacity. I plan to mount it backwards, i.e. the hinge towards the cab. This should give me the clearance i need to mount a gooseneck to the frame just behind where the scissor will mount to the frame. I will then build a trap door into the floor of the body to allow me to flip it open and hook up the gooseneck. I will probably have to build it up some to get it close flush with the bed floor. I also plan to use a ball that can be flipped over. Save me from having to aim for a ball that is below the bed floor.
Thoughts? Really the only thing I am unsure about is mounting the scissor lift backwards. I can not come up with any reason why it shouldn't work, but figured I would get a few other opinions.
Fire away!!
__________________
Robert
2003 F-350 CCLB, Frame off restoration in progress
2002 F-250 ECLB, Parts hauler
2002 Excursion, Twin hauler
  #2
Old 08-31-2016, 04:55 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
no issue running the hoist backwards.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
