11-16 F250 with 7” lift What size tires?
oli6578
Orange, TX
About to go to a 7 inch lift on my 16 F250 wanting to run 38x13.5 but don’t want tires to rub. My wheels are 20x10 with -24 offset. Does anybody know if 38s will fit without rubbing or trimming? Pics would be nice it anybody has some. Thanks in advance!!
Betarocker
Sea to Sky, BC
7" lift, 38x13.50-18 on 18x9 w/ 4.5" BS. Just trimmed the bumper bracket, but I have my axle adjusted forward with One Up Offroad Adjustable Link Arms.
oli6578
Orange, TX
Thanks. I have PMF 3 link so I can adjust my axle also. What size rear block are you running?
oli6578
Orange, TX
What rear springs are you running?
Sent from my iPhone using Tapatalk Pro
Currently running carli/deaver springs for there 4.5 lift. Gonna add 2.5 inch block under springs when I go to a 7 inch lift up front. That would put me 8 inch total height in rear.
oli6578
Orange, TX
Beta rocker,
Could you possible sent a picture of how much you had to trim? Do they rub at full lock off camber?
Houston
I was told to run 1” more in the back than the front to get it level. It worked for me.
In your case that would be 7” springs up front and 4.5” springs + 3.5” blocks in the rear..
YoungMT Hick
Lake Stevens, WA
Could you guys measure wheel well height. I have a 16 and am running 38’s and unsure of the lift. I need to do some trimming as I run on bumper bracket and render mount in yje rear.
Thanks.
