Solid lifter for clearance checks
KBMKVIII
Texas
How have you modified a lifter for checking piston to valve clearance?
Or can we buy a solid lifter for the 7.3?
Purchasing colt stg 2 and before re-assembly I will need to check this measurement.
Block will most likely be surfaced along with the head with possible valve seat work.
Thank you
Zeb
Downtown Marrowbone Ky
I’ve done it with a 6.0 lifter which is the same as a 7.3 lifter. I’ll get you the measurements on the rod I put inside the lifter tomorrow.
Zeb
Here’s what you’ll have when you take the lifter apart.
Zeb
Here’s what you need to make it solid.
I used a bolt that I had, but a 3/8” rod 1.422” long works well also.
I squared the ends in a vise on my surface grinder. It is important that the ends are square so that the top plate doesn’t try to cock sideways.
