Transmission problems
bens
I have a 2014 f350, ******d and tuned with an ez lynk. As i was merging onto the interstate the transmission slammed hard into the next gear i think it was a 3-4 shift. So hard i thought i got rear ended. Anyways i get into town and come to a stop and wouldnt hardly move, the dash indicator showed only 5th gear engaged. So i made it home. It goes into reverse fine, if i go to drive it tries first gear and you can feel it engage for a few seconds, then it "pops" out loudly and goes straight to 5th. Any ideas? Id assume some sort of hard part failure...
Thanks,
Ben
bens
Update... hooked up my scanner to the truck tonight, no trans codes, nothing seemed to be out of the ordinary. I started it put it in drive and it acted normal, went on a short cruise, shifted great by the time the truck warmed up, it started stuttering in first and second gear, so i made it back home. Reverse is strong. Im happy becauseni dont think i have any hard part failure, but maybe an electrical type issue. Any input anyone??
Thanks
i would try different tuning. if it doesnt change then, i would assume some sort of valve body problem.
doo dah
San Antonio
I haven't come across that issue. These transmissions are very strong and even when they are hurt bad they still keep going. You could try unloading and reloading your transmission file and go through the relearn process otherwise it could be related to a shift solenoid.
bens
Thanks for the input guys, as soon as i get it out of winter hibernation i will try reflashing the tcm and going through the relearn.
bens
Well it was a decent day out today, so i reflashed the tcm tune, and went through the relearn. I was driving the truck around to get the transmission warmed up before the procedure. I stopped to shift through all the gears NRNDR or however it goes, but as soon as i got to drive, it did theboriginal thing. I could feel 1st engage, then a loud pop, and it indicated on the dash 5th gear. I drove around 25 miles problem free warming it up. And then all of a sudden it went into its fit of being stuck in 5th gear again.
doo dah
San Antonio
You don't get any codes when it does this? This forum isn't active anymore so I'd try other online resources, post in the '17 and up forum as most of those guys had 11-16s before they upgraded, and maybe call Midwest or the place you bought your tuner from and see if they have any guidance. I bet it is an electronic part and not a hard part.
bens
I ended up taking it to the stealership to be diagnosed, and of course they said bad trans. They couldn't tell me why but would have been more than happy to keep digging into it for $175 an hour. Long story short I now have a midwest street trans. I still feel like it could have been a simple problem, but now my worries are over and I have a warranty.
Sent from my SM-G892A using Tapatalk
bens
I did not drop the pan but pulled a sample from the dipstick tube and it was black and seemed to have clutch particles.
dsmracing1
Alberta, Canada
Hate to say it bud but the stealership is right. Pull the pan and verify but if your fluid is burnt and you have clutch material, she’s cooked....
bens
Post #9 I bought a midwest street trans and worry free now. Lol
bens
I don't even know why mine blew up I was kind of disappointed. It probably had a hard previous life before I bought the truck.
dsmracing1
Alberta, Canada
More than likely yep. I always let mine warm up before I let her eat haha
Ackerdiesel
Western Ky
The pan is not a good indicator of trans life in these things. Just fwiw...
Sent from my iPhone using Tapatalk Pro
bens
How much did that run you including instillation?
If I remember right, in the ballpark of 6k. That was with a heavy duty torque converter, all schaefers fluid, and I got the egr lightened at the same time.
SpyderX
Boaz, Alabama
Thanks for your time. Did Midwest install for you?
