01 f-350 on 20x12 ?????'s
1badpsd
lebanon,tn
Im converting my long bed dually to a single wheel and plan on running 20x12 with-44 offset with 33 12.50 toyos. I have a 3 inch leveling kit so what im wondering is will they rub? Thanks guys
David N
Eastern NC
I run 20x12's with 33x13.50's and I have minimal rub with just a 2" leveling kit. I had to trim the front valence and the lower part of the inner fender. And it doesn't it the spring. But your's being a F350 and a 3" leveling kit, you should clear that no problem. And if there is any trimming, it would be hardly any at all.
1badpsd
lebanon,tn
Thanks so much for the info. I had 22.5s with 255/70 (37's) and they barely rubbed at full lock but im new to the single wheels and offsets and all that
smokedout250
harrisburg oregon
You should only rub inner fender.... I'm running 35s on 20x10s -24mm and I'm only running 2.5" leveling kit
MINK
London,OH
It wont rub.
Add-a-leaf, 33x12.50 Toyos and 20x12s
Terry_7.3
Crawfordsville IN
Running 325/50r20 which are equivalent to 33x13.5 on some 20x12's with stock suspension. I rub on inner driver side fender some. I just have to trim it a little and it will be fine.
07powerstroke91
I have 33x13.50 on 20x12's and at first they rubbed quite a bit. I had to do some trimming of the OEM Lariat flares, and now they just rub on the inner fender. You could definitely make it work with no rubbing at all I just don't like the idea of taking sawzalls and hammers to my truck lol
MINK
London,OH
05+ have a wider front axle which is why you had a issue with the flare when the leaf spring trucks dont.
1badpsd
lebanon,tn
Bump this back up. I actually lifted the front another inch and had 4.5 inch blocks made for the rear. Would I be able to clear 35's now?
