Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #21
Old 02-11-2018, 05:03 PM
Fixemall Fixemall is offline
Private
Member's Gallery
Default
Great thanks for all the comments
  #22
Old 02-11-2018, 05:32 PM
Private
Member's Gallery
Default
One last question is there a certain year 7.3 that is better than the others?
  #23
Old 02-11-2018, 05:51 PM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
IMO;
1997 for the OBS
2000 for the SD
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #24
Old 02-11-2018, 06:07 PM
Private
Member's Gallery
Default
Quote:
Originally Posted by mandkole View Post
IMO;
1997 for the OBS
2000 for the SD
Okay thanks
  #25
Old 02-11-2018, 06:42 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
I'm sure 01 and newer get hated on for being PMR but I wouldn't let that you turn down a clean one. I have one and it's been beat to piss and still continues to be
__________________
Teamsters Local 444- Rolling Coal United
  #26
Old 02-11-2018, 08:03 PM
threegenpowerstroke98 threegenpowerstroke98 is offline
Sergeant
Member's Gallery
Default
PMR isn't an issue unless you're making big power. imo I've had every iteration of the 7.3 from 89 to 01 and they're all work horses. 94.5 to 97 and 99 to 03 are all solid trucks and differences between the trucks within a generation is minimal from my experience and research.
__________________
01 ccsb lariat, custom straight pipes, php tunes, edge cts II dead but not forgotten
11 ecsb xlt, 325/60r20s, 20x10 pro-comp rims, mpd budget t4, sxe 364.5, H&S intercooler pipes, G3arhead tuning, five inch flo-pro to 6 inch tip, minimaxx, 514rwhp, 908 ib/t torque on bald tires
  #27
Old 02-11-2018, 08:24 PM
Private
Member's Gallery
Default
Quote:
Okay thanks for the comment I really appreciate all the input
  #28
Old 02-19-2018, 04:17 PM
mcnance865 mcnance865 is offline
Private
Member's Gallery
Default
You will definitely want a crew cab. I kick myself everyday for not wanting one when I bought the truck about 12 years ago. The back seat is really only good for small children and throwing some junk back there, plus trying to load it is a pain because the suicide door does not swing all the way back to the bed like newer trucks.
As far as years, if you are planning to get into the 500 to to 500+ rwhp range, then a year 2000 would be the best due to forged rods and quirks from the E99/L99 worked out.
__________________
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
  #29
Old 02-20-2018, 09:38 PM
m j m j is offline
Major
Member's Gallery
Default
GEM modules are what keep me hating the SD and 05+
work truck is an 01 7.3 and we have an 05 6.0 money pit here in the driveway.
for the $$ the 6.0 ate a 7.3 would be faster then you need,
not sure how someone can say you need deep pockets to make a powerful 7.3 while comparing it to a 6.0 where you need deep pockets to keep it stock
__________________
Quote:
Originally Posted by Chvyrkr
BTS transmissions have the absolute top of the line hard parts and clutches, in every single one.....every once in a while that somebody like Mike O or Charles gets a different piece, because they've broken his normal piece.
  #30
Old 02-20-2018, 10:13 PM
Denver's Avatar
Denver Denver is offline
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by Fixemall View Post
Is there any suggestions on whether I should look for a extended cab long bed or a 4dr long or short pros and cons or is it more personal preference
Get the crewcab. I have both a supercab and crewcab. The supercab is noisy and the doors move. All the paint is worn off where the weather stripping contacts the inside of the door. It happens on crewcabs as well but not nearly as bad. My supercab has the door seal mod and is still noisier and has more air draft than my crewcab that doesn't have the door seal mod.
2000 and prior have stronger rods in the engine. 2002-03 have nicer interior. Since the newest 7.3 is already approaching 16 years old I would take the first one you like regardless of model year.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
