Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #101
Old 09-04-2018, 03:18 PM
DieselDC's Avatar
DieselDC DieselDC is offline
Sergeant
Member's Gallery
Default
I forgot what’s going on but you should use wd40 and not ether.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
  #102
Old 09-04-2018, 03:19 PM
Dirtclod's Avatar
Dirtclod Dirtclod is offline
Lieutenant
Member's Gallery
Default
Fuel pressure is good,oil level is good.
__________________
01 F-250 4x4 cc/sb 238/100 inj,adrenaline hpop,reg return fuel system,s&b intake,4” elec conduit straight back exhaust,KC stage 1 turbo,hd built auto tranny,pohp hydra chip custom tunes,still needs alot it’s work in progress.
  #103
Old 09-04-2018, 03:20 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Quote:
—————signature—————
I’ll shoot him a text. Thanks
__________________
  #104
Old 09-07-2018, 10:13 AM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Well I went to the mechanics shop and I got it fired off. It’s running rough but to be expected with a new hpop and injectors. My problem is very little turbo boost. I have to really put it down to squeeze 10 lbs out of it. It’s the kc stage 1 turbo. Now I understand it’s probably not big enough for my 238/80’s but shouldn’t it be doing better? Egts were cool what little I ran it. Bout 4 miles. I’ve contacted them by email just waiting for a response. Hopefully it’s an easy fix.
__________________
  #105
Old 09-07-2018, 12:34 PM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Running cool + low boost = not enough fuel.
With those injectors you should he able to peg 1,000 pretty easily.
Stock tuning maybe? Bad boost gauge?
Sent from my SAMSUNG-SM-G930A using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #106
Old 09-07-2018, 01:09 PM
KCTurbos KCTurbos is offline
Major
Member's Gallery
Default
What tune are you running?
Does it smoke like crazy at only 10psi of boost?
  #107
Old 09-08-2018, 04:21 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Gh tuning boost gauge is ok. I think you might be right about fuel. Smoking white and strong diesel smell. It’s going back in the shop to have the oil dipstick tube fixed at the oil pan. I’ll have him check it all out. I think it’s got a leak in the inter cooling and y pipe somewhere to. It’s time to put new boots and clamps on anyways.
__________________
  #108
Old 09-08-2018, 04:22 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Man this sounds like it’s costing some coin.
—————signature—————
  #109
Old 09-09-2018, 10:38 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Yep I’ve definitely put some $ in it. Yes it’s smoking when you touch the pedal. Strong fuel smell at idle also. The mechanic said he saw a fuel leak but I haven’t saw it leaking anywhere. I haven’t done anything to it since I got it home. Been working night shift for a week and transition back to days tomorrow so really hadn’t had time. When I was driving it I had 4th setting I think tow/ street. I’m going to order all new boots and clamps and change them out. Hopefully that will seal up any leaks.
__________________
  #110
Old 09-11-2018, 05:04 AM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Yesterday I took all the boots off and replaced the clamps. Found a small fuel leak on the supply side just before the split to the heads. I drove it about 40 miles to a shop to drop it off and I tried the other tunes out. Street,heavy tow,stealth,all out. I’d been running in tow/economy. The other tunes would spool up to 27-28lb. But throttle response was slow. Lots of smoke with a mix of black and white with a steady haze the whole ride. This guy is very familiar with our trucks and has a built 7.3 of his own so I’m sure he’ll have it figured out soon.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
