Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #111
Old 09-11-2018, 09:24 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Dirtclod View Post
Yesterday I took all the boots off and replaced the clamps. Found a small fuel leak on the supply side just before the split to the heads. I drove it about 40 miles to a shop to drop it off and I tried the other tunes out. Street,heavy tow,stealth,all out. I’d been running in tow/economy. The other tunes would spool up to 27-28lb. But throttle response was slow. Lots of smoke with a mix of black and white with a steady haze the whole ride. This guy is very familiar with our trucks and has a built 7.3 of his own so I’m sure he’ll have it figured out soon.
Still sounds like you have a boost leak. Are you running a waste gate?
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #112
Old 10-10-2018, 11:38 AM
Dirtclod's Avatar
Dirtclod Dirtclod is offline
Lieutenant
Member's Gallery
Default
Ok here’s a another update. Yes I am running a wastegate. My ICP is bad and either my stock fuel pump is not going to big enough or it’s weak,according to the mechanic. Also I may not have programmed the hydra chip right so it might be running on stock computer. Or something isn’t right with the chip and just needs updated. Also there is a fuel leak off the return side under the truck. He sounds pretty optimistic that it’s a simple fix.
__________________
01 F-250 4x4 cc/sb 238/100 inj,adrenaline hpop,reg return fuel system,s&b intake,4” elec conduit straight back exhaust,KC stage 1 turbo,hd built auto tranny,pohp hydra chip custom tunes,still needs alot it’s work in progress.
  #113
Old 10-10-2018, 11:42 AM
DieselDC's Avatar
DieselDC DieselDC is offline
Sergeant
Member's Gallery
Default Time to do injectors
Hydra has two options once plugged in
1. On
2. No start (stock tuning will not run with it plugged jn)
What injectors were you running again? Been awhile looking at the thread.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
  #114
Old 10-10-2018, 01:15 PM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
When doing tunes with Matt at ******** he pulled the tube from the wastegate when I had the exact issues.. He said that is they way it should be. That was several years ago
but is the way it has been with his tunes.
__________________
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, GH Tunes w/160/30s, S&B cold air intake, 4-inch turbo-back exhaust, Garrett 38r, Adrenaline HPOP, BTS Transmission w/6.0 cooler, Swamps IDM(broke, back to stock), AIC, in-tank and pre-pump mod, Heater valve mod, X-car sound panel mod
  #115
Old 10-10-2018, 01:19 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Quote:
1. On
—————signature—————
238/100’s
__________________
  #116
Old 10-10-2018, 01:20 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Ok I’ll pass that on to my mechanic. Thanks for the replies.
__________________
  #117
Old 10-10-2018, 06:50 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
I forgot to mension this,but he thinks for some reason and maybe because the icp sensor isn’t working correctly that the computer is having 2 shots of fuel delivered like it would for split shot injectors instead of a single shot of fuel. Now all that is over my head. I have read some stuff as to where an icp sensor or ipr valve or something else there related would cause the pcm to try and compensate for lack of whatever just to keep the engine alive. Would this cause a situation for overfueling? Or say cause the injector to stay open ping too much fuel into the cylinder?
__________________
  #118
Old 10-11-2018, 04:47 AM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
How much do you trust this mechanic, does he do a lot of diesel work or is it just some dude in a garage?
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #119
Old 10-11-2018, 05:17 AM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
I trust him to an extent. He and his partner only work on diesel pickups. His personal truck is a Superduty 7.3 99-03. It’s also modified. I know that don’t mean squat. I’m giving him till the end of the week to figure it out.
__________________
  #120
Old 10-11-2018, 05:44 AM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Quote:
That’s all he works on. His personal truck is a 99-03 7.3. If he can’t figure this out by the end of the week I’ll take it to Full Throttle performance. It’ll be a month or so before they can work it in but if know they’re good.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
