Wide Open 7.3 Race Motor
Powerstroked162
On Da Juice
Wa. State
Welp, the time has come to move on to a new platform so the 7.3 truck has to go. Gonna throw the motor up for sale as a package, turbo to oil pan. Build has less than 1000k miles on it and hasn't seen any injectables. No expense was spared when I had Zane build it and I can assure you that he cut no corners. Motor comes with the following:
WOP Cryo'd and Hardblok filled engine block
WOP Race ported and polished cylinder heads
WOP Fire rings
WOP Cam
WOP Bottom end girdle
WOP Cryo'd crank
Hypermax mount kit
WOP up-pipe waste gate setup w/ twin 40mm Turbosmart waste gates
WOP KASB turbocharger
WOP Intake plenums with nitrous spray bars
Swamps 400/200 injectors
Swamps Gen3
Swamps IDM
WOP Cryo'd flex plate
DI Pushrods
DI Regulated return
Hypermax Hardened valve seats
Hypermax Inconel valves
Hypermax Vlave springs
WOP Cryo'd rocker arms
Mahle coated pistons w/ valve reliefs and milled/decompressed bowls
Total seal piston ring kit
Melling LPOP
New Ford oil pan, front timing cover, IPR, ICP sensor, water pump, etc.,
ATI Harmonic balancer
I think thats everything. I'll try to remember if I forgot anything in there or not. At this point I am not really interested in parting it out. I'd like to move the whole thing, turbo to oil pan if possible. Im well over $45k into this. Asking $19,500 for the package, turbo to oil pan. I can get build pictures up for those interested. This is a great turn-key setup that is every bit of 1000krwhp capable. I just don't have the drive or time to peruse it. Great buy for somebody looking to get a new built motor at half the cost.
Serious inquires only, please. Price is *somewhat* firm. I will work out a shipping deal with a buyer. Can even offer up an install deal for those interested and local to or near Washington.
Thanks guys.
~Steve
