6.4 brake downsizing to fit smaller wheels for slicks
Status
Not open for further replies.
Dzchey21
wyoming
Thanks ryan! (aka Kind)
This is for 4wd trucks
Brake back dating parts list.
- 532591 12.9 M14x40 metric cap screw x8
- CCA18-B4752 Cardone Ford 2003 F350 4wd right rear brake caliper(with mounting bracket) x 2
- CCA18-B4753 Cardone Ford 2003 F350 4wd left rear brake caliper(with mounting bracket) x2
- AE7626M brake pad set x2
- 48-86823 NAPA Ford 2003 4wd premium rear brake rotor x 4
- 8C3Z 6W650 A Ford 6.0 diesel turbo to exhaust outlet silicon hose x1
- LM104949 NAPA Ford 1999-2004 F350 rea axle wheel bearing x2
- 916X3X11ST HD plus (9/16" diameter 3" wide 11" high) square-top HD spring u-bolt x4
- UBW65 HD plus (9/16") thick u-bolt washer x8
- DN9/16GR8 HD plus(9/16") deep u-bolt nut x 8
- HUB 184 Motorcraft 1999-2004 Ford F350 super duty rear axle hub assembly x2
- BRS 116 Motorcraft 1999-2004 Ford F350 super duty rear axle wheel seal x2
- F81Z 1244 AB Ford 1999-2004 F350 super duty rear axle bearing x2
- F81Z 4670 AA Ford 1999-2004 F350 super duty rear axle slinger x2
- 1/8 alum rivets x8
- 62747 M14X2.0X40 PLTD GR 10.9 MTRC HH C/S x4
- M14 GR 10 metric flat washer x8
- 88449 1/4 USS TRU-TORQ x1
- 88452 3/4 USS TRU-TORQ x1
Machine work
- 2 of the 4 rear rotors need to be machined for clearance in the front. The parking drum and the pilot.
- 4 wheel spacers 3/16" thick. Front and rear are the same thickness but the rear is a different pilot diameter
- 4 bushings for rear calipers. 16.25mm x 14.45mm x 19.10mm
(O.D) (I.D) (Long)
Supposedly this is a royal pain in the a*s. The rear is fairly strait forward but the front requires verbal persuasion.
If anyone needs assistance I can direct you to the shop that did this to Roger Smith's truck, just PM me.
Ryan
Status
