Merry Christmas to Me!
JDelaney
Medical Lake, Wa
Unlimited 238/100s. I put a set of those and a S369SXE in a buddy's truck last year and really like how it runs. With the 364.5 I'll be down a bit on the top end but it should run pretty good on the bottom through the mid range.
ja_cain
Sweet!
Swaan
You'd be surprised. I bet it won't be down too much on the top end just smoke a bit compared to the 69
JDelaney
Medical Lake, Wa
The hot set up a few years ago was a set of 238s and 38R. I figured since the 364.5 outflows the 38R that it should do just fine. I'll have to line up with my buddy's truck and see, lol.
The Brad
People's Republic of CA
I’m curious to see what you think about 30 vs. 80% nozzles for daily driving. 30s are recommended pretty often by vendors on FB, but loathed on the forums. Obviously 160s and 238s are no comparison, but for normal driving, you’re probably using less than 100cc.
Is your SXE a 68 or 74mm turbine? A 1.00 housing will be a good idea!
TMCCOY
Utah
That much injector should make a big difference! I bet the 364.5 will do fine. Worst case, swapping a 366 or 369 isn't too bad by the time you pimp the 364.5... Check out 1023 tunes, I bought 4 and they're the best yet. Enjoy the head studs in chassis, I bet they'll be fun! What is the reputed boost limit for stock bolts & HG's anyway??
JDelaney
Medical Lake, Wa
I put 238/100s, 369, studs, springs, and pushrods in a buddy's truck last year. The 369 doesn't spool nearly as fast as a 364.5 but damn does it run on the top end! Head studs aren't bad. Just unbolt a motor mount and jack the engine up.
superpsd
Missouri
Cylinder presure is what blows the gaskets. Which varies a lot with load, fueling, rpm, timing, (tuning) etc. Too much timing advance with heavy fueling at low engine speeds pulling a heavy load and POP. I do believe some have pushed past the 500hp limit on stock bolts. Its a roll of the dice. Hp isnt a gasket killer anyways the torque is. Increasing the torque output is indication of increased cylinder pressure.
JDelaney
Medical Lake, Wa
Driving around in my economy tune the turbo seems to keep up pretty good. I played around on the freeway the other day in the higher settings and things definitely start happening quickly! Didn't really have time to check the tailpipe and it was raining lightly so it would have been difficult at best to gauge smoke. But I did see 45 PSI and a buried speedo.
JDelaney
Medical Lake, Wa
Not wastegated. I have no doubt that the 364.5 is running out of steam up top but the truck won't see WOT in the all out setting very often.
Swaan
Sounds like an awesome setup!! ������
