How to adjust the fIPL on a 7.3 idi
JoeDaddy
Gridley Ks
I think he means the fips, fuel injection pressure screw. Just Google it there millions of links.
G Racing
Southeast Texas
Fuel injector pump lever. You should be able to set it by backprobing the wire in the middle of the sensor connector. You are looking for 1 volt. You can loosen the sensor and turn it if it is out of spec.
