Gen3 hpop questions
campbellflage
Hudson, FL
Bought off another member and will be doing install here shortly.
1. Use new stock gasket for install? Mine used the one with the screen, when I bought this hpop it was covered in grey rtv.
2. What’s the hex nut on the bottom of the gen3, it covers one of the holes in the gasket (see pic with gasket). Remove it?
3. Anyone run an oil bypass setup with one of these in place?
Thanks all!
DieselDC
It’s better if you call swamps and talk to Jonathan as he will give you all the info you need. Btw you making a race motor??? That’s big oil!!!
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
campbellflage
Hudson, FL
—————signature—————
Not a race motor, 300/200s goin in
DieselDC
Nice! Definitely need gen3 for them injectors. Them sticks are competition sticks for sure! This will be a fun daily!
—————signature—————
DZL JIM
North East Ohio
What issues are you seeing to think the Gen 3 is too much?
I ran my own version daily driving and it sucked. Too many quirks to make it worth while.
My HB Sr. supported my 300/200% enough to hold 3800 psi at wide open throttle, so a Gen 3 isn't the only option for 300/200%'s.
Magnum PD
VA
Get up above 1500 rpm or so and the duty cycle will be in the single digits and the computer will throw a code and go into the 725 psi default
