Go Back   PowerStrokeArmy > Premium Vendors > Dyno Proven
Reply
Thread Tools Display Modes
  #41
Old 04-04-2016, 11:56 PM
thuglike's Avatar
thuglike thuglike is offline
Major
Member's Gallery
Default
Sorry guys...been away a bit.
The cap itself does not (I am 99% sure but will double check with Jon) have a pressure relief spring in it. The tank has a hose barb just below the cap that acts like a pressure vent. It just blows off excess pressure. A hose attached straight down from the barb will keep the front of the motor clean as some coolant will, at times, leak. (not much). It's real nice if you run a non-pressure coolant, like Evans, there is no drilling the cap to vent excess pressure build up you get from time to time.
Again, I will double check this to verify.
Sorry for the delay.
Jason
  #42
Old 06-14-2016, 09:15 PM
psmike psmike is offline
Sergeant
Member's Gallery
Default
Any news on the OBS tanks ?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
