sunrisefordparts
So does that mean my truck is stuck in 2wd then? Or do I need a complete new t-case, or what would you recommend?
prob your best bet is to check with a local trans shop and see if they can get aftermarket parts for your tcase which is a warner4407 tcase, with the number 6SA they should be able to get the info they need. or search online and see what you can find out.
Strokin572
Billings, MT Local 406
Hopefully I can find one soon there's alot of mud out there right now... I go in 2wd but there's only so much I can do :fustrate:
sunrisefordparts
May I get a price on brake pads and rotors. 2009 Mustang pony edition V6. I can get the vin if needed.
oem parts
front pads list $91.63 sell $65.98
front rotors list $112.03 each sell $80.66 each
rear pads list $83.30 sell $59.98
rear rotors list $58.30 each sell 41.98 each
motorcraft
front pads list $66.63 sell $47.98
front rotor list $99.97 each sell $71.98 each
rear pads list $66.63 sell $47.98
rear rotors list $74.97 each sell $53.98 each
free shipping
q#291840
Txpsd
I need a price on the 4 rubber insulator pads that go in the corners of the AC condenser. This is for a 2001 F250 CCSB. Also need the tailgate hinge that'll allow me to run an 08-13 gate on my truck. Thanks!
sunrisefordparts
looks like the rubber is part of the bracket,
uppers list $15.78 each sell $11.36 each
lh lower list $13.80 sell $9.94
rh lower list $11.92 sell $8.58
hinge list $12.75 sell $9.18
free shipping
q#292034
Txpsd
free shipping
q#292034
I need to also add the frame side front bumper mounting brackets to this quote. I need both sides. Thanks!
Dzchey21
wyoming
New online site is slick guys used it last week for a shift tube on this 6.0 im trying to sell.
Same great prices and fast shipping
Txpsd
which bracket are you looking for.
Turns out I can't use the bracket I was wanting to. The 05 bumper doesn't line up with the earlier bracket's holes.
I do, however, need the vinyl Ford cover that fills the gap under the hood between the grill and radiator. Same 2001 truck, thanks!
sunrisefordparts
shield list $116.15 sell $83.63
q#292224
free shipping
