Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 06-16-2017, 09:56 AM
6.0bored 6.0bored is offline
Private
Member's Gallery
Default 2015 6.7 f350 reliability fixes
Looking for options to loose the missile silo under my dad's 6.7. What have you all done? Truck has about 55k on it.
Thanks in advance.
Sent from my SM-N910V using Tapatalk
__________________
2006 F-350 Lariat Fx4 6.0L
138XXX Miles on Truck 1XXX on Rebuild Motor
To many Mods to list
  #2
Old 06-16-2017, 10:48 AM
powerstrokelyfe's Avatar
powerstrokelyfe powerstrokelyfe is offline
Sergeant
Member's Gallery
Default
Sct x4 with custom tunes, *** pipe, e** turned off. That's really it.
__________________
12 f250 6.7L: SCT custom tunes
  #3
Old 06-16-2017, 05:29 PM
stevens6.7 stevens6.7 is offline
Lieutenant
Member's Gallery
Default
Just contact Mike at No Limit (bigrpwr) I believe is his screen name on here. He will give you all the options you need with excellent customer service as well.
__________________
13 Sterling Gray CCSB FX4 6.7
  #4
Old 06-16-2017, 07:32 PM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
Quote:
X100. Run GH tuning, you'll be a very happy.
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #5
Old 06-19-2017, 04:55 PM
Private
Member's Gallery
Default
Thx for the input. Will look into these.
__________________
  #6
Private
Member's Gallery
Default
Is it better to remove egr junk?
__________________
  #7
Old 06-19-2017, 10:01 PM
LovinPSDs LovinPSDs is offline
Major
Member's Gallery
Default
Should he k o'clock out the intercooler pipe as well?
What else is there to make these things 100% solid?
__________________
2005 - 6.0 - Mods in progress
12' TDI Jetta
  #8
Old 06-20-2017, 04:04 AM
Jomax's Avatar
General
Member's Gallery
Default
Yes for sure. Also cleans up the engine bay.
The BEST thing to keep these reliable is maintain them. Keep up on oil, coolants, fuel filters etc.
I have 110k miles on my 2015 and I use it... some people say I abuse it, but honestly running these trucks hard don't hurt them IMO. I have my intervals way less then what ford recommends.
Engine oil 10k miles (LE fill syn oil)
Trans (drain every 10k with LE trans oil)
Fuel filters 10k miles
Air filter 10k miles
Coolant 36k miles
Brake fluid 36k miles or once a year
Rear diff oil 20k miles
Front diff 20-40k miles
Transfer case 20k miles
PS fluid 20k miles (I just suck it out with a syringe as much as. I can so I don't have to bleed it)
Maintaining the truck is #1, I'm anal though, I even keep every fuel receipt and every one is numbered, I'm currently at receipt #550.
__________________
  #9
Jomax's Avatar
General
Member's Gallery
Default
Yes, he should get a H&S Intercooler pipe upgrade for sure.
__________________
  #10
Old 06-20-2017, 05:06 PM
Private
Member's Gallery
Default
Coolant 36k miles
U certainly do use your truck! Yes I've had him keep ontop of maintenance, just not on the intervals you have. Might have to tighten some up.
I did the tranny at 30k.
Was thinking I'd run CAT ELC after ******s, unless there's a different school of thought.
Haven't touched diffs or brake/PS as of yet.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
