Brake lights don't work
bigbill78
I have an 02 f350 drw 7.3 that the brake lights don't work. Blinkers, flashers, tail lights all work. But no brake lights. I have replaced the brake switch and it blew at brake switch not the fuse. On the brake switch the terminal for brakes is burned. Also my electric brake control don't work and my left blinker is lit when lights are on. Anyone have any ideas?
Sent from my LM-V350 using Tapatalk
greyford1979
Copley,Ohio
Did you check the wires at the back of the truck underneath near the frame? I had issues with my 2000 F250 like this. The harness was rubbing on the frame and rubbed right trough the insulation causing a short. I ran all new wiring from that spot. I didn't have any issues with the brake switch though.
