1949 F6, 06 4wd axles.
isootmypants
North Jersey
Pops and I building a 49 f6 rat rod style. Got 06 axles under it, BTS e40d, and a 700hp 12v. ( he wanted to do a 12v haha ). Anyways, I got a question on trans set up. I want a ratchet shifter, but then still need it programmable for shifting. PCS is what I was looking at but do I need a harness from an obs? Or does the PCS just control everything? Power and ground to the controller and PCS trans harness. Run wire to tps and that's it? Need a little info. Thanks
Six_Sloww
Southeast MI
I don't think there's a manual vb for an e40d, unless you just mean you want a floor shifter.
You can order the pcs with an e40d harness I think.
co04cobra
WV
Cool build! I can't agree with a 12v, lol, but still very cool project.
Strokersace
Towanda, KS
I have a 51 F3 that I'm going to be building over the next several years.
As bad as I wanted to put a Powerstroke in it, I don't think there's any way possible to fit one under the narrowed hood. A Cummins is the only way to go.
I'm doing a twin turbo 12v as well but doing a zf6 behind it. My goal is for it to be as mechanical as possible...
isootmypants
North Jersey
Haha I was debating on putting a 7.3 in it cause I have everything for them but my dad grew up working on big trucks and believes no diesel should be more than an inline 6 haha
tow mater style. no hood..
if a mechanical 7.3 can go in a mustang, there is no reason it shouldnt go in a truck..
Strokersace
Towanda, KS
It's not just the narrowed hood, it's also that the inside of the fenders narrow significantly towards the front too.
I measured every which way from Sunday, and it would require a lot of cutting. Something that I am not willing to do.
there is someone on this forum with a 7.3 in a mid 50s i believe...
Strokersace
Towanda, KS
The 53 - 56 have more room than the 48 - 52. Starting in 57 they went to a full Hood and engine compartment.
I'm not saying it can't be done. Just not something that I am going to do. I want it to look bone stock with the hood and all fom the front.
Besides, if I wanted to put a psd in it, it wouldn't be a 7.3. It'd be a 6.0 or 6.7. But I didn't want that many electronics. Mechanical engine and trans is the way I'm going.
I'm with you...
party pooper.. i mentioned a mechanical 7.3.. lol.. i do get what you are saying though.
buuuut, you could stretch the front end a lil.. lol
regardless, it will be a sweet project bud!!
except the inline part
Skill_Kills
Princeton MN
Looks like it will work well with how you did the front frame section. I wish i had done mine differently. It's possible to do a 7.3 in a 48-52 just cant use fender wells and IIRC the motor has to be sat pretty low. There's quite a lot of room in my 53 especially on the passenger side. hardest part was keeping it short enough to fit under the hood with how i mounted the motor but it was kind of necessary if I wanted to keep the 53 VIN and title as a 53
isootmypants
North Jersey
Yea there's the latest. Sorry forgot I had this thread on here Haha. 4 link in back, 3 link in front. Motor already for pick up at millers machine shop.
