Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 05-16-2018, 12:27 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
Lieutenant
Member's Gallery
Default VGT Solenoid Connector
I broke one of the locking tabs off the VGT connector this weekend, looking to change over from the style with the 2 plastic tabs to the wire bail style connector. Does anyone know if you can or how to remove the wires from the connector so that I can just replace the connector itself and not have to cut/splice wiring?
__________________
05 F350 CCLB 4x4 PSD
97 F350 CCLB 4x4 PSD - sold
Quote:
Originally Posted by Powerstroked162 View Post
WhiteduallyIL is a rubber penis
  #2
Old 05-16-2018, 04:18 PM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
Very carefully! Lol
__________________
I'm sweatin' like a wh*re in church here!
  #3
Old 05-16-2018, 04:19 PM
Colonel
Member's Gallery
Default
In all seriousness, the pins are held in via clips on the plastic. Should be able to use a pick or something to unclip them and pull them out the back.
__________________
  #4
Old 05-16-2018, 04:54 PM
Lieutenant
Member's Gallery
Default
Quote:
I was messing with an old 7.3 injector harness I have, and it looks to me like I'd have to release a retaining tab, slide the pin out the front, bend 2 little ears down, then pull it out the back. I'm just nervous to try and pull that off without f*cking up the pin so I was hoping someone else had tried it and had some pointers.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
