6th Annual Cass County Truck & Tractor Pull
HDDP86
The 6th Annual Cass County Truck & Tractor Pull will be held on June 4th at the Cass County Fairgrounds in Virginia, IL. Admission is still the same at $10. Beginning this year, kids 10 and under are FREE. Pit passes will still be $20. Beverages will be provided by A. Gaudio & Sons, Inc. Food will be provided by the Virginia BBQ. The hook fee remains the same at $30. A driver of a competing vehicle and one additional person will get in free. Please note that there are NO REFUNDS for general admission or pit passes. The only refunds given will be in the instance of breakage. Example: If a truck is signed up for two classes and breaks in the first class, the competitor will be refunded their hook fee for the additional class they signed up for.
*NEW THIS YEAR*- Passengers will be allowed in the non-sanctioned truck classes. Those classes are the Factory Turbo, Open, and Semi classes. Limit one (1) passenger and they must be at least 18 years of age. Be ready to show your ID. The passenger must also be in the truck when weighing on the scale and sign up with their driver. If you are not signed up with the driver, you will not be able to ride, no exceptions. All safety equipment such as a secured passenger seat, seatbelt, etc will be required. Please do not complicate this as it has taken quite a while to get this going.
*NO OUTSIDE ALCOHOL IS ALLOWED. There are no warnings with this rule, you will be asked to leave immediately. This will be patrolled heavily throughout the day again.*
*Only competition vehicles or trucks/trailers hauling competition vehicles will be allowed in the pit. As most of you know, parking can get pretty congested in the pit area so please be respectful to the volunteers at the gate with this rule. Last year was another prime example as to why we do it this way.*
*The pull will begin at 1:00 with IFPA tractor classes running first. Trucks will start shortly after the tractor classes. Pull order is not yet determined for the trucks. Trucks should be on the premises no later than 2:30.
Let's make it another great year in Virginia!
IFPA Tractor Classes-
www.ifpapull.com
- 9500# and 10,200# Pro Farm
- 11,500# and 13,500# Farm Stock
Central Illinois Truck Pullers Classes-
Rules for both gas and diesel pickup classes (except Factory Turbo and Open) can be found at http://www.centralillinoistruckpullers.com/
- 7000# Factory Stock
- 6500# Super Stock
- 6200# Modified
- 6200# 2WD
Diesel Truck Classes-
- 9500# Factory Turbo
- 8500# Workstock
- 8000# 2.5
- Open (Gas and Diesel)
Semis-
20,000# Street Legal Semis: No added weight or ballast is permitted. Fifth wheel position must be no further forward than the center of the front drive axle and no further back than the center between the two drive axles.
PAYOUTS-
CITP Gas Classes
Factory Gas
1st- $150
2nd- $100
3rd- $75
Super Stock and Modified
1st- $250
2nd- $120
3rd- $75
9500# Factory Turbo Diesel-
1st- $200
2nd- $120
3rd- $50
8500# Workstock Diesel-
1st- $400
2nd- $200
3rd- $100
4th- $50
8000# 2.5
1st- $300
2nd- $200
3rd- $100
4th- $50
Open *4 trucks in the class will be required for a payout*
1st- $200
2nd- $120
3rd- $50
Semis
1st- $250
2nd- $120
3rd- $50
NO REFUNDS
