littlerobert1983
- Joined
- Apr 24, 2017
- Messages
- 37
- Reaction score
- 0
I replaced glow plugs then drove truck to put fuel in it and ran completely out. I know not healthy by any means,fuel bowl had setiments and dirt in bottom. Cleaned fuel bowl and filled fuel bowl and installed new filter. Truck will drive around block and quit once it's warm. Have replaced cps ipr and icp to no change at all! How do I check fuel pressure on this? Also do you think the lift pump could be out bc when it quits and I remove filter the is only about an inch of fuel in fuel bowl. Truck runs great at idle but under load it will stumble and drop rpms until it just quits and then it's hard to start. There is white smoke coming from exhaust. I do not have access to any scanner so that is ruled out to use at all. I have also ordered new idm 120 volt coming I'm mail just to make sure it's not that. Could you plea see help me with this issue I don't know what 3lse to do at all. Truck has no programs and new injectors 12,000 miles ago and new turbo installed a same time. Please help!
Sent from my SM-S920L using Tapatalk
