Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #11
Old 10-14-2020, 06:08 AM
Jonnydime's Avatar
Jonnydime Jonnydime is offline
Major
Member's Gallery
Default
Quote:
Originally Posted by sootie View Post
Which rod did it throw, #7?
Is there something special about number 7?
  #12
Old 10-14-2020, 07:44 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
nope. just that that is the one that had the issue prior to the "repair"
  #13
Old 10-14-2020, 02:49 PM
Jonnydime's Avatar
Major
Member's Gallery
Default
I completely missed that post. Woops
  #14
Old 10-14-2020, 06:57 PM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by ToMang07 View Post
Sounds like you incorrectly self-diagnosed and don't want to pay for your error.
Sucks... but I can't see how this is the the shops fault. If they installed the heads incorrectly sure. But sounds like your motor was already fukked.
Sent from my SM-G960U using Tapatalk
Looks like you missed the line that said "Mechanic agreed." Mechanic diagnosis too.
__________________
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, GH Tunes w/160/30s, S&B cold air intake, 4-inch turbo-back exhaust, Garrett 38r, Adrenaline HPOP, BTS Transmission w/6.0 cooler, Swamps IDM(broke, back to stock), AIC, in-tank and pre-pump mod, Heater valve mod, X-car sound panel mod
  #15
Old 10-15-2020, 07:12 AM
ToMang07's Avatar
ToMang07 ToMang07 is offline
General
Member's Gallery
Default
Quote:
Was that supposed to mean the mechanic diagnosed it or just that they agreed to do what the owner wanted? Because from what I read they just agreed to what the owner diagnosed.
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, Hydra, 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, T500, FRx, COMP 910s, Fisher 8' MM2, 5" AL 1-piece Drive Shaft, Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203* TS and Billet Housing, ELC, Fumoto, Leveled, Airlift Bags, 16x10" on 35s, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing... Rebuilt Transmission at 137k~AE w/Ford Pack~
  #16
Old 10-16-2020, 05:39 AM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
That's also my thought.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #17
Old 10-16-2020, 01:29 PM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
My thought is that the owner thought it was a cracked head and took it to the mechanic with the symptoms and the mechanic checked the symptoms and agreed. If the owner took it in and just said to replace the heads then that is a different story. I guess clarification is really needed.
Wonder if they checked the heads as too if they really were cracked.
__________________
  #18
Old 10-26-2020, 11:06 AM
jmorty33 jmorty33 is offline
Private
Member's Gallery
Default
Mechanic ran the engine, ran diagnostic tests, etc .... and diagnosed it himself after I described what was going on. He sent me an estimate only after he confirmed what he thought was the problem and what repair needed to be done.
  #19
Old 10-26-2020, 09:21 PM
webb06's Avatar
webb06 webb06 is offline
Colonel
Member's Gallery
Default
Id like to see what the exact code was and the cracked head. Never heard of a 6.7 with cracked head causing coolant out exhaust.
But if this were in our shop and the rod failure was unrelated to original repair then youd be paying the bill.
  #20
Old 10-28-2020, 06:42 AM
tomlin tomlin is offline
Private
Member's Gallery
Default
Sounds like it did in fact get coolant in the cylinder at some point. Could be a crack, head gasket or sucked in from someplace else. It probably tried to hydro lock or did at some point and bent the rod. Hence the balance code, likely due to low compression in the hole. You need to sit down with your mechanic and work out an arrangement that suits you both. Its not entirely your fault and it is not entirely his, one thing to remember, anytime coolant or any liquid gets into the combustion chamber and the engine is ran or attempted to be ran, the possibility of hydro lock exists. Hydro lock equals a bent or broken rod.
__________________
2000 f350 super cab dually
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
