Honey Badger Sr. V 1.0
thuglike
Linden, NJ
The Sr. itself is still a little way off BUT.............................
We do have an alternative to anyone who has a SRP1 HPOP.
If you send in that pump for 300.00 Jonathan will re-build your pump into a HB Sr.
So you send in the SRP 1 and 300.00 you get back a HB Sr. with our warranty and after sale service.
Jonathan will be in here soon to explain the transition.
Bearings are changed
Honing is done along with a few other tweeks. Like I said Jon will be here soon to explain
what about a hbj thats still in the same box and plastic it came in when the first hundred sold and upgrade was promised?
Magnum PD
VA
There is just too much stress in stock housing to be able to move that much oil and be able to stay intact. What they had planned didn't pan out.
thuglike
Linden, NJ
The original Sr. did not pan out. With big oil being an emotional topic we had to be sure the Sr. would be everything we said it would be.
psduser1
on the road
Glad to see someone stepping up to mess with these. I've got two srps, both have been pretty reliable.
Knock on wood.
