lets talk sumps
1badpsd
lebanon,tn
Im looking at doin a sump soon and was just wondering if there's any difference in a hellman and tsd sump. Is either one better than the other?
vapstroke
Jackson, Wy/ Fairfax, Va
I haven't seen a tsd sump in person but I have a Hellman sump on my truck. It's a nice piece the only thing I did was find some thicker nylon washers for it because the ones that came with it seemed to distort a bit when tightened down. I picked up the new washers at the local hardware store for about two dollars.
389sixpack
New Jersey
TEXASMEDIC01
Texas
I have two TSD sumps, one on each truck. I like their styling. They are more streamlined IMHO, can be made in any color, and at the time the price was a little cheaper than alternatives I had found.
Hotrodtractor
Mingo, Ohio
I just installed a TSD sump on a truck - very nice piece - my only complaint is how much the outlet port is recessed - but it sure isn't enough to keep me from buying one. In fact I will probably be buying another one here in the near future for another truck I am working on.
Irontx
Texas
That's really nice man.
I have a Hellman sump on mine. Shiniest thing on my truck. Whoever you go with, it's worth it. Shouldn't try a fuel system without it. Sucks not getting that extra quarter tank with the stock draw straw.
389sixpack
New Jersey
Whatever brand you go with, make sure you have good filtration and a water separator. Everything on the bottom of your tank is now heading to the injectors. Need good fuel system for a bottom feeder.
young7.3
Southern Indiana
Theres not much to talk about. Just pick a sump, they all do the same thing. Im rockin a TSD black one and like its low profile.
1badpsd
lebanon,tn
I've had an AirDog 2 and just in the last 2 months its started with the quarter tank problem and ive been Puttin it off but its time to fix it.
Chris
San Antonio, TX
Heres a pic of our sumps. Any sump will solve your 1/4 tank issue if installed correctly, and they will all make the fuel pump of your choice a much happier camper. It boils down to personal preference and customer service. BTW Nigel, that sump is freaking awesome! You running 4 fuel labs off that thing?!
