Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 11-08-2018, 08:01 AM
Diesel625 Diesel625 is offline
Corporal
Member's Gallery
Default 6.0 bullet proof fan upgrade
I finally went ahead and upgraded to the manual fan clutch. My electrical clutch would work when it wanted so I figured Id try it out. It works great. The AC is even colder than it has ever been. Has anyone ever had any issues with this setup?
  #2
Old 11-08-2018, 11:28 AM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Why would you have issues?
Sent from my SM-N960U using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #3
Old 11-08-2018, 03:38 PM
Bryce_fow Bryce_fow is offline
Sergeant
Member's Gallery
Default
Yes make sure the wire wheel the pulley or the belt will scream at highway speeds when it kicks on
  #4
Old 11-08-2018, 04:49 PM
Corporal
Member's Gallery
Default
I was wondering about the harness not being plugged in any longer. I know it throws a soft code, just wondering about the electronic side.
  #5
Old 11-09-2018, 05:00 AM
Sergeant
Member's Gallery
Default
It does throw a soft code but I have 3 6.0s and all have the bpd fan never had a issue
  #6
Old 11-09-2018, 09:17 AM
Jtreece's Avatar
Jtreece Jtreece is offline
Sergeant
Member's Gallery
Default
I know this is a mechanical fan clutch now but what temp does it fully engage and disengage? I was curious because I am going to do the swap over summer because my 6.0 likes to run hot.
__________________
04 F350 CCLW SRW, 35's, CM skirted flatbed, Diablo T1000, SCT3, Studded, *******, 4", Stage 2 Tranny, blue spring, wicked wheel, loves to eat Hondas.
  #7
Old 11-11-2018, 09:37 AM
Extended Power's Avatar
Extended Power Extended Power is offline
Major
Member's Gallery
Default
I ditched the whole bigA$$ fan, and went with four electric fans.
No fan can move as much air, as your truck moving down the road at 50+ mph.
__________________
2003 F350 King Ranch ccsb 4x4
793hp fuel only
12.2 @ 113.06mph
  #8
Old 11-19-2018, 02:18 PM
Jtreece's Avatar
Sergeant
Member's Gallery
Default
So how does it work? temps?
__________________
  #9
Old 11-19-2018, 07:01 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
What controller you using?
__________________
Teamsters Local 444- Rolling Coal United
  #10
Old 11-20-2018, 10:32 AM
Major
Member's Gallery
Default
No controller....don't trust them.
Toggle switch. On/Off (Using relays of course)
Faster warm up, then just turn them on, and leave it on until I shut the truck off.
Holds 190 no problem.
If I do a foot to the floor "Run", it gets to 210, and then cools right back down again.
__________________
793hp fuel only
12.2 @ 113.06mph
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
