Grinding/Clunking when shifting into park.
DudeManScott
97 7.3 E4OD 4x4 BW4407
Just put a new e40d in my truck. While filling it up and shifting through the gears it was shifting fine. Did this a few times to ensure I had fluid in the entire transmission.
All of a sudden now when I shift back into park after shifting through the gears it's makes some strange grinding/clunking noises for a few seconds. From the research I have done it sounds like something in the TCase.
What should I check first?
Also not sure if this is normal or not. But when I shift into 4x4 with the truck off/in park (key on) the 4x4 shifter bounces back into 2wd (won't stay in the 4x4 position)
