6.0 Oil Cooler Delete Plates
Zmann
Id imagine the same way the bpd kit does. Mounts the same but doesn't get hot sitting. The big air to oil cooler takes care of that.
not sure what your implying in your BPD mounting comparison ?
the BPD mounts in a different location and requires the removal of the condenser coils ( major downside IMHO) thats why I like this setup so far
an air to oil cooler is not very efficient without the air part actually moving
just like a coolant to oil cooler if the water pump was removed
so what I am wondering is about the actual airflow when stationary
strokin6L
Springville NY
The BPD kit doesn't require the removal of the condenser coils. Last i knew...there's two mounting options for the cooler. Either behind the front bumper or behind the A/C condenser
Jarrod B
Corpus Christi Texas
I did a bpd oil cooler delete on my sisters ex and it was a pita. But it worked.
I'm wanting to know how this mounts and cost.
It should get it's air flow cause the fan is still spinning.
Zmann
check again
it's 1 option for mounting and it requires the condenser out
or you can get creative but it's not recommended because you may puncture the condenser with the tapping screws
also if u have the wrong style PS cooler you have to replace it
IDK why the BPD inside the bumper original version is gone but I bet it's cause of air flow from the fan same reason I think it's not in front of the condenser now
Jarrod as you know OEM is a puller fan it's going to pull the most air from the path of least resistance so up high and last in line is what I see from this unit
not saying that may not be fine but they will need to test it and I am sure they will
PSM_Kid
Houston, Tx
check again
I agree that it sucks on late 06-07 models having to go to a earlier power steering cooler, but it is what it is. But when mounting the cooler to a OEM condenser there are usually several holes available to put the supplied tapping screws into. It is fairly easy to look on the side of the condenser and see which of those holes will lead to a tapping screw puncturing the condenser.
I don't get what you mean when you say "or you can get creative but it's not recommended because you may puncture the condenser with the tapping screws", because that is what the instructions call for you to do, mount it to the condenser :confused:.
strokin6L
Springville NY
check again
They musta changed their kit around then...cause they did have two mounting options.
Zmann
they have a way to do it without removing the condenser all the way
but then your limited on seeing the clearance when yo do the self tapers so you have to be careful
and the reason they don't have this method in the directions is that it's not recommended
Pizza pig
MD
No updates, too much to do, not enough time. We are currently sold out of these plates, and have 2 6.4 ones left. Making a run sometime soon.
ford rules
Ever get any more done on this setup? wondering where you guys mounted the oil filter?
Pizza pig
MD
we have plates in stock and more running of the CNC tomorrow. No updates on a kit, other than we arent doing one at this time. Not enough hours in the day, were trying to get the hot products out for the demand we have.
Bobby@MPD
No, they are still on hold for now.. We are running off the 6.4 turbo kits...We still have the oil cooler plates & fittings in stock.
jcordova904
Info?
Here is our Filter for the 6.0 and 6.4 kits... E Series 6.0L Filter housing. We are in the process of machining the custom Plates for the In/Out of the filter head, ORB fittings made from billet so it will be easy for the end user to create their own setups. The plates will also work for the van oil head on the oil cooler, so you will also be able to use the OEM oil cooler and relocate the oil filter and still use the fuel bowl by using the van parts... stay tuned.
Can please get some info on doing this on my 6.0
