Low Fuel Rail Pressure at start up Long crank
F350eightyAM
My truck is slow to start. The fuel rail pressure is low at first while cranking then the pressure builds up in 3-4 second into the crank then starts. Any ideas of what it could be. ??? I've had electrical issues with the alternator over charging( 16V )replaced that today.
Dzchey21
wyoming
could be a number of things, High pressure fuel leak, High pressure fuel pump issue ect. Is your engine oil overfull? That would indicate a leak.
